Old 01-25-2018, 04:44 AM   #1
itzryry
Drives: 2013 Scion Fr-s
Problem Shifting into gears.
Hey, if anyone could help me figure out what this problem is or any ideas would be much appreciated.
I Have a 2013 Scion FRS. When the car reaches normal operation temp. Sometimes I wont be able to shift into any gears after I come to a complete stop, it would completely lock me out. I would either have to hold my clutch in for a couple seconds and it would shift without any problems or just hold the clutch in the whole time at stop light.
I installed an ACT clutch Kit W/ lighten Flywheel. Also installed a new clutch slave slave cylinder thinking it would fix the problem.
itzryry is offline   Reply With Quote
Old 01-25-2018, 04:51 AM   #2
swarb
Did you have the problem before the clutch/flywheel install? Was the clutch grab point adjusted after the install?
Old 01-25-2018, 04:58 AM   #3
itzryry
No I didn't have the problem before. I also didn't adjust the grab point.
Old 01-25-2018, 05:12 AM   #4
swarb
Maybe you should do that.
Did you bleed the clutch too?
Old 01-25-2018, 11:02 AM   #5
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
If you have a problem shifting after a clutch install the first place to look is clutch drag. There are several sources - installation error and part defect/performance are high on the list.
I'm assuming you replaced the TOB. Did you reuse the OEM clutch fork?
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 01-25-2018, 04:50 PM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
These guys above me are probably right, since it happened right after the new clutch and flywheel install.
But I'll toss in just for fun (since it's a 2013) check and make sure your motor mounts are in good shape. If the engine flexes too much on bad mounts it can cause shifting issues. You know with the massive torque this beefy engine creates, it causes all kinds of issues
Old 01-25-2018, 07:19 PM   #7
humfrz
There ya go. Even if you did those things, I suggest you do (check) them again.
humfrz
Shifting Problem (Automatic) FRSure Issues | Warranty | Recalls / TSB 61 05-09-2021 07:38 PM
Automatic Transmission Kick/Choke when shifting gears Tech Gremlin Engine, Exhaust, Transmission 13 06-16-2015 01:54 AM
Squeaks when shifting gears/happens every 15 or so seconds while holding speed Simon99 Issues | Warranty | Recalls / TSB 10 10-11-2014 03:54 PM
AFR leaning out after shifting gears Toyota John Software Tuning 14 05-23-2014 01:05 AM
Clunking gears when shifting? hmkk Issues | Warranty | Recalls / TSB 4 02-19-2014 06:14 PM
