Old 06-30-2019, 09:28 PM   #1
SmoothIsSlow
Socket size for OEM struct bolts
Hi all!
I am getting ready to install SPC 81305 into the front lower struct hole and move the OEM 14mm bolts to the top struct holes.
It seems like the SPC bolts need 15 and 18mm sockets. What sockets do I need for the OEM bolts?
I tried searching around but came up short; would be great if someone could save me the trouble of taking off the front wheel before I run off to Lowe's
Thanks!
SmoothIsSlow is offline   Reply With Quote
Old 06-30-2019, 09:55 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Dude, don't you have a socket set? If not
Go buy both SAS and Metric sets. The more sockets in the kit the better.
The Following 3 Users Say Thank You to Mr.ac For This Useful Post:
humfrz (07-01-2019), Tristor (07-01-2019), wparsons (07-02-2019)
Old 06-30-2019, 10:37 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
As said, get a set, you're going to need it..
Old 07-03-2019, 08:54 AM   #4
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
(Not OP) As someone who has a large socket set there are times where it's handy to know the size before the job. Sometimes you just can't store your tools near your vehicle and it can be a pain to carry the whole set around rather than the 2 or 3 sockets necessary for a job.
Sorry I can't help OP but I haven't done the job yet.
CrowsFeast is offline   Reply With Quote
Old 07-03-2019, 09:43 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Seriously? I have two sets like this, one of them almost lives in my car. It's the size of a large lunchbox and has most everything I need. I have swapped out a few of the SAE sockets and wrenches to have duplicates of metric sizes I use the most.
https://www.lowes.com/pd/Kobalt-227-...hes/1000642747
Old 07-03-2019, 09:49 AM   #6
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
iirc it's like a 17 and a 19, annoying, you need at least 4-5 sizes for the job iirc, I've gotten lazy a few times and just used an adjustable wrench.
Make sure you have a deep socket for the nut on the SPC bolt, the bolt extends far past the nut so a short socket won't get it all the way on.
I found this DIY that calls out all the tools for disassembly:
http://www.ft86club.com/forums/showthread.php?t=10842
Harbor freight man, save yourself a few bucks, hobbyists don't need lifetime warranty tools imho. Buy the whole set that has the one piece you need, repeat until you have just about everything.
Also I don't know what a struct is, but I'm assuming you mean strut.
ineedyourdiddly
Old 07-07-2019, 11:08 PM   #7
SmoothIsSlow
Oops, been programming too much C at work, said struct when i meant struc
I ended up buying a nice 224 piece set from Lowe's. Splurged a little but man it's nice to have tools finally.
For future reference, the OEM bolts and nuts are all 19mm. The SPC lower bolt are different for the nut vs bolt head: 15mm and 18mm.
The Following User Says Thank You to SmoothIsSlow For This Useful Post:
Mr.ac (07-07-2019)
WTB: Stud Bolts OEM Size redtwin Canada Classifieds 3 12-22-2017 02:50 PM
McGard wheel lock, wrench socket size dssence Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 02-27-2014 02:09 PM
Which star socket for front seat bolts? stockysnail Cosmetic Modification (Interior/Exterior/Lighting) 1 08-31-2013 02:46 PM
02 Sensor Socket Size? swift996 Engine, Exhaust, Transmission 6 08-19-2013 09:30 PM
What socket size and what torque amount for stock alloy wheels? Takeshi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-01-2012 10:25 PM
