Old 05-22-2019, 01:07 PM   #1
mcnvgget
mcnvgget's Avatar
Drives: 2018 Toyota 86
spacers
anyone know what size spacer i could get a flush fit with 18x8.5’s? they tuck in a bit and since tein doesn’t go super low it looks a bit off i think
mcnvgget is offline   Reply With Quote
Old 05-22-2019, 01:18 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I can help... What offset are your wheels? Do you know how much camber you are running?
I LIKE TIRES!
Old 05-22-2019, 01:23 PM   #3
mcnvgget
mcnvgget's Avatar
i’m running 18x8.5 +30 all around and no it’s camber from just lowering the car i haven’t messed with the camber plates in the front and haven’t done nothing to the rear, the front i have them maxed out lowered and the rear are about a quarter of an inch from maxed
Old 05-22-2019, 01:50 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
So, with your offset and estimated camber, Id suggest these... You will need extended studs to use these spacers. I'm running them and love them.
https://www.ebay.com/itm/4pcs-12mm-5...ox!97412!US!-1
You will have to add more front camber. There isnt a bolt on solution. (besides different wheels) Bolt on spacers, thin enough to work, would require shaving the OEM studs. zthe slip style spacer I have linked, requires longer studs. I have been running inexpensive Ebay studs for 30k miles, but everyone suggests ARP studs.
I LIKE TIRES!
FS: 5mm spacers toeout Wheels and Tires 2 05-11-2017 11:04 AM
Spacers nanofamous Want-To-Buy Requests 1 03-14-2017 02:12 PM
5mm Spacers? azynneo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 10-20-2015 05:37 PM
Spacers... Help!! Sabretooth Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 04-13-2015 11:33 AM
Spacers mpicher Tracking / Autocross / HPDE / Drifting 20 08-15-2013 09:45 AM
