Old 04-08-2015, 03:33 PM   #1
Sabretooth
Drives: 2015 Scion FR-S
Spacers... Help!!
I just bought 2 half inch (12mm) spacers for the rear wheels since they are tucking, but when I put the wheel back on after the spacer is put on there is not enough thread for me to put the lug caps . How do I get them on ?
Sabretooth is offline   Reply With Quote
Old 04-08-2015, 03:36 PM   #2
Vampyre
Vampyre's Avatar
Drives: 2014 FR-S Asphalt
Purchase longer wheel studs, replace stock ones, or return spacers and buy ones with wheel studs in them.
Vampyre is offline   Reply With Quote
Old 04-08-2015, 03:39 PM   #3
8R6
8R6's Avatar
Drives: FRS
thats because you need extended studs for any space thicker than 5mm. Or you can get spacers that have studs already bolted into them like mentioned above.
8R6 is offline   Reply With Quote
Old 04-08-2015, 03:47 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
yup, like others said...need new/longer studs
Old 04-08-2015, 08:29 PM   #5
UMB FR-S
UMB FR-S's Avatar
Drives: Ultramarine Blue FR-S
Buy wheels with correct offset!
-- Kenny
"I don't always use heel/toe, but when I do it's because racecar."
UMB FR-S is offline   Reply With Quote
Old 04-09-2015, 12:22 AM   #6
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Or buy spacers manufactured with bolts in them, anything over 5mm will need longer wheel studs
. ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 04-12-2015, 03:59 AM   #7
WRKHARD
Drives: 13' FRS
do your research when buying spacers. Companies like H&r and ichiba (v1) sell application specific spacers that come with extended studs.
Old studs will need to be pressed out/new pressed in. Easiest done with the hub removed from the car. There are some nice write ups front/rear on this forum.
If you go with a spacer that has built in studs, again, DO YOUR RESEARCH. Stay away from that option if at all possible. There are far too many horror stories out there of people losing wheels going down the highway because of those.
Long story short, do your research, dont be cheap, measure twice, buy once.
WRKHARD is offline   Reply With Quote
Old 04-13-2015, 11:33 AM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I know two types of people that run bolt-on spacers:
1) people who don't check the torque specs of their spacers on a regular basis (or didn't install them correctly). These same people also never check their cars on a regular basis
2) those that are the opposite of #1
It's not an issue if you install and maintain properly. The horror stories are from neglect and ignorance.
-alex
H&R DRM spacers set Swabe Wheels and Tires 10 09-13-2015 11:48 PM
NY/NJ 5mm PBM spacers MAKK NY / NJ / CT / PA 5 01-11-2015 10:52 PM
Spacers vs Spacers Black_Pearl Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-11-2014 12:11 AM
WTB: Spacers abutterman Wheels and Tires 3 05-12-2013 06:11 PM
30 mm spacers possible? Maps316 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-08-2013 04:14 AM
