Old 08-02-2013, 05:48 AM   #1
mpicher
Autocross Nut
mpicher's Avatar
Drives: Argento 2013 Scion FR-S - MT
Spacers
Anybody in RTR or Stock/Street running spacers or tried them and not running them now?
I've checked a few of the builds posted but haven't seen mention of them.
Thanks,
Mike
mpicher is offline   Reply With Quote
Old 08-02-2013, 08:26 AM   #2
edj
edj's Avatar
Drives: 2022 Toyota GR86
i use 1/4" spacers on the front with my Kosei wheels (+50 ET) so that
the 245 Hoosiers fit but that is all. when i go to street tires next year
the spacers will not be required.
the extra 1/2" of track width may help a little but it is within the noise...
plus the lug nuts do not screw on the wheel studs enough that i would
trust them on the street. you would need to get longer studs.
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
Old 08-02-2013, 10:30 AM   #3
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
not legal for the most part.. 1/4in isn't alot of room to play with. Just buy the correct offset wheel. if its a clearance issue. I agree with EDJ. if you can get at least 5 turns on the lug nut, it should be sufficient.
Bill
Scooby South is offline   Reply With Quote
Old 08-02-2013, 02:25 PM   #4
mpicher
Autocross Nut
mpicher's Avatar
Well, I'm thinking I need to swap out of the crappy OE studs anyway.... I've stripped 2 (i was setting torque to 95, backed it down to 89).
Spacers are legal in RTR / Stock / Street... just not much... up to 5mm. My AutoX wheel is the 17" Kosei K1-TS.
The Kosei's seem to show more stud than the stock rims... Maybe I just need some open ended nuts instead. Maybe with the closed end nuts I'm causing them to strip? Grasping at straws here. I've had lugs for years with my Cooper & never had this problem.
Old 08-02-2013, 02:38 PM   #5
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
The OE lugs suck, replace them ASAP.
I've had issues, Simmons has had issues, Holly broke 2 or 3 herself as well. It's not you. They are crap.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
The Following 2 Users Say Thank You to Sccabrz192 For This Useful Post:
mpicher (08-02-2013), Scooby South (08-02-2013)
Old 08-02-2013, 05:03 PM   #6
mpicher
Autocross Nut
mpicher's Avatar
What studs are you guys using?
This is why I'm thinking if I replace them, go a bit longer, add a 5mm spacer to get a tad wider stance. Plus the H&R 5mm spacers come with studs. STONE ---> two birds
If the spacer's aren't worth it... I'll just source studs.
Old 08-02-2013, 10:01 PM   #7
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I'm on 50mm offset 17" Kosei K1-TS wheels in RTR as well. If I could find a good quality 3mm (or maybe 5mm if there are enough threads left on the studs) lightweight spacer that was lugcentric and hubcentric and wasn't too expensive, I'd give them a try. I've used H&R's in the past on other cars, and was happy with their quality. I'd rather not change studs at this time.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 08-03-2013, 02:31 AM   #8
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I replaced my studs with ARP 10MM extended studs.
With the stock studs there was a ton of metal shavings during every wheel change.
Old 08-03-2013, 04:48 AM   #9
mpicher
Autocross Nut
mpicher's Avatar
Blaine, with that stud length what nuts did you end up using? The prices on some of these nuts are crazy for something I'm going to drop on the ground twice an autocross day...
On the studs, I assume you mean the ARP 100-7716
Old 08-03-2013, 02:14 PM   #10
BlaineWasHere
Grip>Drift
Drives: FRS
I bought the ARP studs for WRX, they can be found here:
http://www.rallysportdirect.com/ARP-...2-2011-WRX-STI
I'm just using Blox aluminum/open ended lugs. They are about $70-80 for a set. Mine look like crap now but they are light and I don't see metal shavings during tire changes with this combo. I am using anti-seize also.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
mpicher (08-03-2013)
Old 08-04-2013, 09:20 AM   #11
mpicher
Autocross Nut
mpicher's Avatar
ok... ARP studs & Blox on the way :-)... screw the spacers for now but I'll have enough thread if I want to try some.
Old 08-04-2013, 02:28 PM   #12
BlaineWasHere
Grip>Drift
Drives: FRS
I ran them without spacers for a while but I have 5mm spacers all around now because I moved up to 255 and 17x9 et45 was a little to tight and the wheel was hitting control arm in the front at full lock. Plus I like the freedom of being able to change the offsets with spacers safely. The longer studs make wheel changes much easier.
Old 08-06-2013, 11:50 PM   #13
Razz
Razz's Avatar
Drives: Fast
I would never use spacers due to wheel weight.
Set up your car properly, not mickey mouse.
Razz is offline   Reply With Quote
Old 08-07-2013, 02:29 AM   #14
BlaineWasHere
Grip>Drift
Drives: FRS
Wheel weight? The 5mm spacers weigh a few ounces. Literally like 3oz.
WTB: Spacers abutterman Wheels and Tires 3 05-12-2013 06:11 PM
Spacers recomendation, please! kombatlion Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 04-25-2013 05:21 PM
Spacers and Strengthening Snozzberries Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 04-02-2013 11:42 AM
Will WRX (GD) top hat spacers work on the BRZ? chim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-12-2013 08:56 PM
30 mm spacers possible? Maps316 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-08-2013 04:14 AM
