Old 05-19-2019, 11:52 PM   #1
EzyBreezy
EzyBreezy's Avatar
Drives: 2016 Subaru BRZ (ZC6)
New Rear Tires & Alignment now unstable
Saturday 05/18/2019 I went to get my safety inspection done at a local shop I regularly visit for inspections & emissions. my 2016 Subaru BRZ failed for rear tire tread being low I called around and settled to get tires done same day at Pep Boys. I wanted all 4 but the inventory was wrong and settled for just two even tho they had a promotion buy 3 tires 4th one free . Took give or take 4 hours to complete the installation of only 2 tires in the rear Kumho KU22 (Kumho Ecsta 4X II) tires installed. One of the managers comes up and informs me that he believes prior person to have worked on my car broke or didn't properly install my lug nut and he wouldn't be able to quote me for the fix. I figured i'll fix it myself later. He said they might be able to get it on there but just wanted to inform me. I asked for them to just leave it off but he informed me he couldn't per policy. I pick up my ride and ask the technician what bolt was the problem he shares that it was another team member who experienced the problem and it felt fine to him.
I drive off and the car feel fine I get on the parkway and go to over take someone at about 55 to 58 mph and when switching lanes my cars traction control kicks on and brakes feel as if they are locking up. The car almost feels like a boat. I try and reproduce the problem at low speeds like 30mph and nothing. I only experience the problem at 50mph+ when turning.
[ame]http://youtu.be/n95U7N3RfTk[/ame]
  • I have taken off the wheels and checked them visually and reinstalled them making sure they are tight.
  • I inflated the tires from 30psi to 40psi and tested and still experience the same problem.
  • The problem only happens when going around a curve or changing lanes.
I intend to go back to the shop if I cant resolve the problem on my own but due to work schedule it will have to be this upcoming Saturday.
If someone has had this issue before or experience please share what to look at.
Thanks
Last edited by EzyBreezy; 05-20-2019 at 09:45 PM. Reason: adding a youtube video recorded from mobile phone
EzyBreezy is offline   Reply With Quote
Old 05-20-2019, 12:12 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
That sucks,
Did they actually do the alignment? Sounds like the toe is off.
As for the tires those Kumhos those are some greasy tires new. If they non directional try putting them on the other side. If that doesn't work a nice burn out would take that layer of oil off the threads.
Our lsd are really sensitive with low psi tires that must have been the reason why it freaked out.
Besides that nothing much you can do. Eventually they will even out.
There's is always hope that putting new tires up front can fix it, but eh maybe.
Old 05-20-2019, 12:14 AM   #3
EzyBreezy
EzyBreezy's Avatar
Alignment
Tire Specs
Photo from rear left facing driver seat
Edited to include additional images
Old 05-20-2019, 12:27 AM   #4
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
That rear right camber is something i would bitch about.
I would tell them to match the left rear.
4 fucking hours and they couldn't get this shit right?
Nothing pisses me off more than alignment mechanics that can't fucking make thing equal especially when they have a computerized alignment rig.
Old 05-20-2019, 12:46 AM   #5
EzyBreezy
EzyBreezy's Avatar
That sucks,
Thanks i'll try rotating the tires and see if problem persists if it does ill give a shot.
Old 05-20-2019, 02:03 AM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
What tread level is your front tires at?
If you press-hold the traction control to disable it, does all the warnings/problems go away?
My suspicion is that the front tires tread depth is low enough that the vehicle is reading the difference in the circumference of the tires(a tire with full tread is going to move further in one rotation than a tire with 1/4 tread depth), and is thinking that the car is sliding.
Old 05-20-2019, 02:17 AM   #7
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
New tires can be slippery. Drop the rear psi?
Old 05-20-2019, 10:01 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
What tires were you running before these? They might just have less traction and you are used to more.
My Mazda 3 came with these tires and I wasn't particularly impressed, seems a run of the mill all season. Not great in rain, got me through 2 inches of snow barely but not able to go up hill. They were better than the Ecsta PA31 I got stuck with on my Honda Accord though.
These days I stick with separate summer and winter sets.
You could try swapping front and rear tires as well.
Rear camber is not adjustable stock so I wouldn't bother complaining about it.
Old 05-20-2019, 10:30 AM   #9
ls1ac
ls1ac's Avatar
Start with simple first. New tires come with mold release on the tread, so first several miles are slippery. Next, a different tire front to back will often do as you noticed. the side wall allow for different movement and the tread will have different traction during turns. go back to the shop and tell them you want four tires with one free. It is their fault they were out of stock.
Old 05-20-2019, 11:10 AM   #10
EzyBreezy
EzyBreezy's Avatar
Front Tire Michelin Primacy HP 215/45R17
"I know it's bad i'll take care of it later."
Rear Tire Kumho Ecsta 4X II 215/45R17
Hey @ls1ac so I'm a contractor at the moment and I'm looking for full time employment on the side. I was interested in the 4 tires at that time but I am fine with two even if they did make a mistake. I want to get some wheels once I secure a full time job and replace all 4 at that time and keep stock for winter and do what @ZionsWrath said he does with his car winter/summer set.
Old 05-20-2019, 05:28 PM   #11
ls1ac
ls1ac's Avatar
Your old tires are basically warn out.
Repeat, go back and get the other two for safe driving. Mixed tires are much less predictable.
The question I usually ask young drivers is, Do you want to stop and turn or get going fast?
Put the good tires on the front and put the old on the back.
I know it will have uneven wear, but you did not rotate before.
Old 05-20-2019, 06:24 PM   #12
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
That's not a good idea bro. Even the manual says to put new tires on the rear. Just a little FYI.
Old 05-20-2019, 06:44 PM   #13
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I think they do that to err on the side of understeer in wet conditions.
Twinz is offline   Reply With Quote
Old 05-20-2019, 07:33 PM   #14
ls1ac
ls1ac's Avatar
Thank you Twins, I also find that understeer is not as easy to control in spirited driving .I prefer to let the tail hand out.
But I repeat get new matched tires and avoid the possible problems of a mismatched set.
Alignment after getting new tires, was this even necessary?(Pic included) Alfrz91 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 02-21-2018 07:50 AM
Unstable idle when A/C cuts out paulca Engine, Exhaust, Transmission 14 10-24-2015 09:18 PM
New front sway, a little unstable on left turns loading_please_wait Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-20-2015 07:38 PM
New wheels/tires=alignment X Factor Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-14-2015 08:20 PM
Unstable feeling Toyobaru808 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-28-2013 11:06 AM
