MisterSheep
Old 02-27-2019, 02:50 AM   #645
jerryzilla
jerryzilla's Avatar
Drives: 2016 Subaru BRZ Series.Hyperblue
Anyone with eddie's tune with base idle timing changes having issues with downshifts where it feels like the car is stumbling?
It almost feels like the car is struggling to rev up properly when rev match downshifting, and my downshifts occasionally are jerky
jerryzilla is offline   Reply With Quote
Old 02-27-2019, 04:42 AM   #646
tomm.brz
Drives: brz 2017 hksv2
that s the downside of pops and bangs since they retard the ignition so much killing the torque
Old 02-27-2019, 04:58 AM   #647
steve99
Drives: FT86
You can fix most of that by not starting the igniton retard in base timing B till over say 3600 or so. Ie dont run retard all the aag down to 800 rpm
Old 02-27-2019, 06:23 AM   #648
tomm.brz
think @jerryzilla modified the overrun timing table, so he gets retarded timings all the time during throttle off situation
steve99 (02-27-2019)
Old 02-27-2019, 12:05 PM   #649
jerryzilla
jerryzilla's Avatar
my brain has been retarded
i remember reading that either here or on facebook. I'm using the base idle timing method with overrun, same concept?
Old 02-27-2019, 12:42 PM   #650
tomm.brz
well you can rescale the base idle timing (overrun) table to let it retard timings only after 3x00 rpm like steve said, and put normal positive timing under it
Old 03-27-2019, 10:55 PM   #651
FR_STEEZ
Drives: 2017 toyota 86
anything updates????
FR_STEEZ is offline   Reply With Quote
Old 04-13-2019, 01:13 PM   #652
eddwvrd
Drives: Frs
So i have an invidia n1 catback and catless resonated front pipe. Will -7 make any pop/crackle? And if i put -10 or -15 will that produce a loud pop? And if im just cruising, is there like an on off for the pops?
eddwvrd is offline   Reply With Quote
Old 04-22-2019, 10:33 PM   #653
CeeJay86
Drives: 2017 GT86
Hey guys was wondering if I could get some help.
So im trying to follow the method eddie posted. The only issue im having is all the tables turn red after I adjust them to the values posted. Any idea what the problem might be?
Sent from my LG-H918 using Tapatalk
CeeJay86 is offline   Reply With Quote
Old 04-23-2019, 05:06 AM   #654
tomm.brz
what you mean are turning red? screenshot?
Old 04-23-2019, 02:43 PM   #655
Kodename47
Kodename47's Avatar
Drives: UK GT86
Is it not just to show you the tables you have changed?
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-23-2019, 05:08 PM   #656
tomm.brz
aah yes understood what he meant.. they get a red border if you make the value higher than initial, a blue border when you make it lower
just be carefull to the actual value you put it s easy to mess a value or a comma, and not notice immediately with romraider
Old 05-10-2019, 12:30 AM   #657
Bisofication
Bisofication's Avatar
Hi all,
I'm trying to implement both methods in Romraider (Table B and OverRun), however, if you look to the left, you can see that the OverRun fueling subcategories are all highlighted in red and when I click on any of the tables I get different and weird numbers unlike most guys above. I'm using the latest OTS tune with its included XML definition of type ZA1JB01C
Bisofication is offline   Reply With Quote
Old 05-10-2019, 06:59 PM   #658
elBarto
elBarto's Avatar
Drives: Toyota GT86
Originally Posted by Bisofication View Post
Hi all,
The def's supplied by OpenFlash are outdated.
I've uploaded an updated B01C def for you. You can use this only with the V4 OFT tunes, do not use it with the older one's!
B01C.zip
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 05:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 06:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 08:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-18-2014 12:07 AM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 03:12 PM
