#645 |
Drives: 2016 Subaru BRZ Series.Hyperblue
Anyone with eddie's tune with base idle timing changes having issues with downshifts where it feels like the car is stumbling?
It almost feels like the car is struggling to rev up properly when rev match downshifting, and my downshifts occasionally are jerky |
#646 |
Drives: brz 2017 hksv2
that s the downside of pops and bangs since they retard the ignition so much killing the torque
#647 | ||
Drives: FT86
You can fix most of that by not starting the igniton retard in base timing B till over say 3600 or so. Ie dont run retard all the aag down to 800 rpm |
#648 |
think @jerryzilla modified the overrun timing table, so he gets retarded timings all the time during throttle off situation
| The Following User Says Thank You to tomm.brz For This Useful Post: | steve99 (02-27-2019) |
#649 | |
i remember reading that either here or on facebook. I'm using the base idle timing method with overrun, same concept? |
#650 |
well you can rescale the base idle timing (overrun) table to let it retard timings only after 3x00 rpm like steve said, and put normal positive timing under it
#652 |
Drives: Frs
So i have an invidia n1 catback and catless resonated front pipe. Will -7 make any pop/crackle? And if i put -10 or -15 will that produce a loud pop? And if im just cruising, is there like an on off for the pops?
#653 |
Drives: 2017 GT86
Hey guys was wondering if I could get some help.
So im trying to follow the method eddie posted. The only issue im having is all the tables turn red after I adjust them to the values posted. Any idea what the problem might be? Sent from my LG-H918 using Tapatalk |
#654 |
what you mean are turning red? screenshot?
#655 |
Drives: UK GT86
Is it not just to show you the tables you have changed?
.: Stealth 86 :.
#656 |
aah yes understood what he meant.. they get a red border if you make the value higher than initial, a blue border when you make it lower
just be carefull to the actual value you put it s easy to mess a value or a comma, and not notice immediately with romraider |
#657 |
Hi all,
I'm trying to implement both methods in Romraider (Table B and OverRun), however, if you look to the left, you can see that the OverRun fueling subcategories are all highlighted in red and when I click on any of the tables I get different and weird numbers unlike most guys above. I'm using the latest OTS tune with its included XML definition of type ZA1JB01C
#658 | |
Drives: Toyota GT86
I've uploaded an updated B01C def for you. You can use this only with the V4 OFT tunes, do not use it with the older one's! B01C.zip
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
| rom tuning for pops and backfires | andrew5826 | Software Tuning | 110 | 12-23-2016 05:39 AM |
| First romraider defs are up | jamesm | Software Tuning | 95 | 01-13-2015 06:29 AM |
| Transient Ignition Retard Tables from RomRaider | Ralph Spoilsport | Issues | Warranty | Recalls / TSB | 31 | 05-24-2014 08:48 AM |
| OFT-Help with Romraider/FFS and Launch Control-issues | continuecrushing | Software Tuning | 9 | 04-18-2014 12:07 AM |
| Possible backfires | Bg8780 | Engine, Exhaust, Transmission | 0 | 05-22-2013 03:12 PM |
