Old 06-24-2012, 06:53 PM   #15
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
Interesting note on the WiFi correlation. It should be noted that Bluetooth and WiFi both use the 2.4GHz range and can interfere with each other.
eriktherod is offline   Reply With Quote
Old 06-24-2012, 07:07 PM   #16
seannyice81
Drives: 2013 Asphalt FR-S
That is an interesting note. I'll have to make sure Wifi is off next time.
seannyice81 is offline   Reply With Quote
Old 06-25-2012, 11:23 PM   #17
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
i found a tweak to disable BT to play music automatically when you turn on your car on a iphone.
note: iphone must be jailbroken
1. download the tweak Bluetooth service manager from cydia
2. run the app
3. uncheck A2DP
and viola! BT music wont play anymore.
BT hands free still works by the way
86_ZN6 is offline   Reply With Quote
Old 06-26-2012, 12:00 AM   #18
r4m3n
r4m3n's Avatar
Drives: Ultramarine FR-S
BTA works just fine for me with my iPhone 4. The only thing I can't do is access playlists. It will only play the current playlist I'm in and to switch I have to shut off the car and manually go to another playlist before reconnecting.
6.4.12 | Ultramarine | SoCal
r4m3n is offline   Reply With Quote
Old 07-01-2012, 12:48 PM   #19
kndonlee
I installed the Pioneer 2400BT and the bluetooth integration with the iphone has been pretty solid. In case you were looking to change out head units.
kndonlee is offline   Reply With Quote
Old 07-01-2012, 12:50 PM   #20
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
No issues with bta and android here with the bespoke unit.
ill86 is offline   Reply With Quote
Old 07-01-2012, 01:58 PM   #21
enigmaaron
enigmaaron's Avatar
Drives: '13 Firestorm FR-S MT, '04 Tacoma
I have no issues with my iPhone 4 (iOS 5.1.1) using BT audio and running Slacker radio. I have the standard head unit. I'm also typically on wifi when I start the car up.
Did you change the connection method for BT audio possibly? It can be set to connect from the vehicle or from the device. I would try switching that.
2. run the app
3. uncheck A2DP
Couldn't you just disconnect (not delete) the BT audio device on the radio? Or does that disconnect the phone too?
enigmaaron is offline   Reply With Quote
Old 07-01-2012, 10:34 PM   #22
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
BTA works fine on my Galaxy Nexus with Android 4.0(ICS)
My gripe is with the audio quality. It sucks.
Chewie4299 is offline   Reply With Quote
Old 07-03-2012, 07:11 PM   #23
JollyJON
JollyJON's Avatar
Drives: DGM Subaru BRZ
i was told by my dealer that you had to sync up your phone twice. once as phone, once as a mediaplayer. i actually didnt read the entire thread so if im talking out of my a** i'm apoligiing right now lol
JollyJON is offline   Reply With Quote
Old 07-17-2012, 04:46 PM   #24
UtahGooner
Gooner & RSL addict.
UtahGooner's Avatar
Drives: 2013 Scion FR-S, Argento / MT
Has anyone seen an issue with controlling the volume when playing bluetooth audio? In calls I can change volume as needed, but cannot control the volume once BTA starts playing. (Phone is a RAZR 4G, stock FR-S tuner)
UtahGooner is offline   Reply With Quote
Old 07-17-2012, 06:34 PM   #25
2pt5RS
Berz
That might be with your selection of music.
Galaxy Nexus and my BRZ BTA = awesome sounding music.
2pt5RS is offline   Reply With Quote
Old 07-17-2012, 06:41 PM   #26
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
I have both an iPhone 4 and a Galaxy SII Skyrocket. iPhone has zero issues playing music. It starts playing as soon as I get the car started and I actually like that. No issues with displaying track names or volume.
My SII on the other hand has some minor problems. One being that the volume isn't adjustable sometimes. I found that if I disable the bluetooth and reenable it then this resolves the issue. I think I normally start the music and if I can't adjust the volume then just disconnect and reconnect even while it's still playing and boom it's fine then. My only other gripe is that it doesn't display the track name whether it's through the regular player or through Spotify. iPhone has no issues with either.
Neither of my phones are hacked in anyway. Both are current on OS (SII on ICS).
phanguy is offline   Reply With Quote
The Following User Says Thank You to phanguy For This Useful Post:
UtahGooner (07-18-2012)
Old 07-17-2012, 06:45 PM   #27
2pt5RS
Berz
itunes tagging is why it displays the track. There's no android profile built into the OS/interface of the radio. That's due to the fragmentation of android.
Old 07-18-2012, 12:34 AM   #28
Blackbeltmma
Drives: Raven Black FRS
I have an iPhone 4S and had the same problem. I accidentally hit the scan button. I re-pressed it and, viola, it worked. Hope this helps a bit.
Raven Frs
I call this car "Therapy"
Happy driving.
Blackbeltmma is offline   Reply With Quote
Bluetooth audio from android phone cgrey Electronics | Audio | NAV | Infotainment 10 07-11-2013 07:56 AM
Bluetooth/Nav inimitable Electronics | Audio | NAV | Infotainment 40 09-26-2012 08:35 PM
Bluetooth built into head unit? finch1750 Electronics | Audio | NAV | Infotainment 8 06-16-2012 02:59 PM
BRZ Bluetooth issues? Shizuma Electronics | Audio | NAV | Infotainment 3 06-13-2012 12:06 AM
Bluetooth Mic Placement in 86? Aventador87 AUSTRALIA 13 06-11-2012 01:36 AM
