Old 10-27-2012, 01:45 AM   #29
soros151
SorosMotorsports
soros151's Avatar
Drives: Whiteout Pearl
Originally Posted by Bahraini86 View Post
Does their crank pulley act as a harmonic damper?
Does the OEM one?
soros151 is offline   Reply With Quote
Old 10-27-2012, 04:05 AM   #30
Celica00
Celica00's Avatar
Drives: 86
Originally Posted by soros151 View Post
Does the OEM one?
yes
Celica00 is offline   Reply With Quote
Old 10-27-2012, 06:08 AM   #31
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
Originally Posted by Celica00 View Post
yes
Actually I've heard no. That it is not dampened
RedRocket is offline   Reply With Quote
Old 10-27-2012, 07:30 AM   #32
Nezz
86DESU
Nezz's Avatar
Drives: 86 GTS, S13, CB9
I have rollcall on the Silvia's back window. JUN and TEIN and Whiteline and a bunch of other lame shit. It's just there for fun. I love seeing rollcall done classy as part of the JDM look-- White vinyl on a white pearl 86 would look nice.
Nezz is offline   Reply With Quote
Old 10-27-2012, 08:46 AM   #33
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
http://www.ft86club.com/forums/showp...9&postcount=22
Jeff86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Jeff86 For This Useful Post:
Bahraini86 (10-27-2012), Celica00 (10-27-2012)
Old 10-27-2012, 06:12 PM   #34
Celica00
Celica00's Avatar
Drives: 86
i'd stay away from whoever youre hearing things from
Old 10-27-2012, 11:57 PM   #35
soros151
SorosMotorsports
soros151's Avatar
Guys... this is an easy fix. Take a an aftermarket pulley to a machine shop and have them examine them and give you the results on how balance is it.
Old 04-21-2019, 12:15 PM   #36
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Just wanted to share some more light on the TODA lightweight pulley kit. I have it installed the last 3 years without any issues, but we had all these endless discussions if a lightweight crank pulley or in general a lightweight kit can provide any "gains" at all just by the weight advantage. I agree that the gains just by the weight difference are almost zero. TODA was mentioning on their site that the alternator pulley was under-driven, but still the pulley's size difference wasn't much and the overall gains should be small. So, it looks that either TODA was cheating or they were mentioning half of the truth. The complete truth is that the entire kit is under-driven (crank, alternator, water pump). Check the difference of the crank pulley size and the alternator pulley size.
Crank pulley:
Alternator pulley:
The crank pulley size difference under-drives the complete system and the alternator pulley size difference under-drives a bit more the alternator. Additionally, the better weight distribution of the crank pulley (OEM has most of the weight on the outside part) and the smaller diameter gives a bit better rotational inertia. It should not be massive, but I believe it helps a bit too.
The Following User Says Thank You to nikitopo For This Useful Post:
chaoskaze (04-24-2019)
Old 04-21-2019, 12:58 PM   #37
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
All numbers count, WEIGHT REDUCTION
Dr. BRZ is offline   Reply With Quote
Old 04-21-2019, 01:20 PM   #38
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
NECRO!!!!!!!!!!!!
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
chaoskaze (04-24-2019), Spuds (04-21-2019)
Old 04-21-2019, 03:25 PM   #39
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Old 04-21-2019, 04:44 PM   #40
86TOYO2k17
Drives: 2017 toyota 86
Just buy fensport under driven water/alt pulley for 1/3rd the price. Use the extra money on a fluidampr or ati super damper crank pulley, or keep oem.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
nikitopo (04-23-2019)
Old 04-23-2019, 01:37 AM   #41
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes you can find much cheaper water/alt pulleys, but they use another material. Most of them use 6061 aluminum and not the 7075. I recall that only Toda and Laile use the 7075 type which is more expensive and stronger. If you hit two pulleys together one with the 6061 and one with the 7075 aluminum, the one with the 6061 will get a crack and the other nothing.
Fluidampr is a good option and I heard that they have also some relationship with DARPA. However, it goes into the opposite direction if you want a smooth running engine without much NVH. It is recommended currently in Japan by tuners for audio makers and demo cars in audio stores.
Old 04-23-2019, 08:55 AM   #42
86TOYO2k17
over-sized under-driven water/alt pulleys* and to my knowledge Fensport and Toda are the only two options. Also Fensport's are incredibly high quality.
Every serious person runs Fluidampr or ATI in their builds. LW crank pulleys do nothing but lighten your wallet. Balancers/dampeners help keep everything running smooth especially the more things you change about how the engine runs compared to stock. Some testing has even shown that increase in dampening ability especially in the higher RPMS reducing internal vibrations actually increased HP. Smoother engine and more HP or losing 3lbs from the equivalency of 1,000lbs of rotational force and possibly decrease the life expectancy of an engine. I guess to each their own right.
Effectiveness of a Lightweight pulley DrifterX Engine, Exhaust, Transmission 94 12-11-2016 01:10 AM
Lightweight pulley wow Silverdub Engine, Exhaust, Transmission 240 01-23-2013 01:00 PM
My lightweight crank pulley experience WolfsFang Engine, Exhaust, Transmission 22 11-29-2012 02:15 AM
FS: Perrin lightweight pulley (Vancouver BC) stanm Canada Classifieds 0 09-15-2012 08:04 AM
Agency Power - Lightweight Pulley Kochinopride Engine, Exhaust, Transmission 42 09-03-2012 11:46 AM
