Old 08-14-2012, 04:51 PM   #1
Kochinopride
Kochinopride's Avatar
Drives: 13 FR-S, 12 CLS AMG, 05 Lotus Elise
Agency Power - Lightweight Pulley
So stupid me I thought I could cut corners removing my pulley without having something to counteract the rotation to loosen the screw... wasted my time pulling apart the intake, but then again - it's not wasted when I get to dissect my car
I bought the Agency Power Pulley and they even gave me the option for what color I wanted! Color?! BLUE?!?!! OK!!!!
Got it today (fast delivery, faster communication!) and I have to wait until I can get my hands on a pulley removal tool... but I have to go to Mexico tomorrow for business but I'll be back to try again on the weekend!!!
Also: Lost a screw bit in the bottom panel... will it fall out eventually while driving or is it going to rattle forever and ever until I get under the car?
Kochinopride is offline   Reply With Quote
Old 08-14-2012, 05:30 PM   #2
empower-auto
Kouki-Monster
empower-auto's Avatar
Cool. I personally like the look of the Perrin one but that's still nice.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 08-14-2012, 05:43 PM   #3
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Do you plan to dyno the part?
Curious if it will make the 14 whp that it did on Vivid's dyno
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 08-14-2012, 05:48 PM   #4
EJ20
EJ20's Avatar
Drives: NA8C, GDB, and R50
No way 14 whp on just a pulley ????
EJ20 is offline   Reply With Quote
Old 08-14-2012, 05:55 PM   #5
xjohnx
Grip>Slip
xjohnx's Avatar
http://www.ft86club.com/forums/showthread.php?t=12558
Old 08-14-2012, 06:01 PM   #6
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Sorry I stand corrected
Their baseline was 153whp 125wtq and a Pulley + Fly wheel showed a gain to 180whp 143wtq which is 27whp and 18wtq while adding headers, crossover pipe and full exhaust to that only gained 14whp and 7wtq
I don't buy these numbers or any dyno posted by Vivid so I was curious if OP would dyno the part or confirm to deny these numbers.
Out of the FRS game
Old 08-14-2012, 06:29 PM   #7
Kochinopride
You know what... That's a goo idea! I'm going to dyno the car before installing it and then a dyno after... I've only installed a K&N air filter in the stock air intake box - should be very subtle difference with that, so let's see how this turns out!!!
And for everyone to know... if you lose a screw under the engine bay... it WILL remain there - so that's good... I guess... but cause it's rolling around!!!
Old 08-14-2012, 06:54 PM   #8
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
Weight of the pulley is 1.0 lb according to their website:
http://www.agency-power.com/catalog/...vctnbdf3jjkao3
Perrin's crank pulley is 1.2 according to their website:
http://www.perrinperformance.com/brz...z-crank-pulley
But depending on where that weight is located they might perform about the same
0.2 lb difference when you include the weight of the rotating crank + pistons and flywheel is pretty negligible
Xanatos is offline   Reply With Quote
Old 08-14-2012, 10:51 PM   #9
Kochinopride
says 1.0lb, but their postings on it said 1.2lbs on their scale. I figured Perrin and AP are the same, just a matter of $5 give or take...
Old 08-14-2012, 10:56 PM   #10
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
What I'm about to say seems obvious, but I'm going to say it anyways. Please make sure you do the baseline and the after install dyno in the same gear. Visconti noticed a 10hp increase in 4th gear vs 3rd gear.
Jidonsu is offline   Reply With Quote
Old 08-14-2012, 11:00 PM   #11
GirlyScions
Drives: Mazda3
So your that guy that leaves screws all over public roads. Thanks because Im the guy that gets em suck in my tires
GirlyScions is offline   Reply With Quote
Old 08-14-2012, 11:15 PM   #12
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
My car had a 7 hp increase in 4th over third. I'll also test my pulley when I get my exhaust done.
Old 08-16-2012, 01:48 AM   #13
Supermassive
Supermassive's Avatar
I got the AP pulley in red, installed it and the butt dyno doesnt really feel a difference, I could give a rat's ass about power gain's of less than 10hp because you wont feel it. What i do like is the revs climb and descend alot faster which is very noticeable from stock. I used to hate how the revs took a second or two to stabilize when you got off the throttle, now its alot better, but I think with the inclusion of a (slightly) lighter clutch/flywheel this car will have an easier to modulate throttle response. I'm used to my superbikes where you can rev to redline in about a second from idle and be back at idle almost as fast (with the clutch pulled in of course).
Supermassive is offline   Reply With Quote
Old 08-28-2012, 05:14 PM   #14
Skywgn1
Skywgn1's Avatar
Drives: 2013 Scion FR-S (manual)
Where did you order it to get the blue? I have only seen Black and Silver.
Skywgn1 is offline   Reply With Quote
Effectiveness of a Lightweight pulley DrifterX Engine, Exhaust, Transmission 94 12-11-2016 01:10 AM
Lightweight pulley wow Silverdub Engine, Exhaust, Transmission 240 01-23-2013 01:00 PM
Agency Power Crank Pulley / Clutch Masters Flywheel vividracing Engine, Exhaust, Transmission 67 11-07-2012 02:35 PM
Agency Power Exhaust vividracing Engine, Exhaust, Bolt-Ons 17 07-23-2012 02:40 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
