Old 04-05-2019, 10:55 AM   #1
Diz86x
Drives: GT86 Nur spec
Weird issue, I NEED HELP !
Hey guys
Im facing an issue with my engine where it has a rough idle and the car sounds somehow louder and different where the acceleration is slower than normal after 3000 rpm and the intake is way loudddddddder !
To add on,
Even if i rev the car everything is okay before 3000 rpm but after that it almost sounds like too much air is entering because the rpm is slow and intake is really loud !
Mods :
Perrin cai
Gram throttle body
Trd catback
I have this mods for a while now but the issue just showed up !
Diz86x is offline   Reply With Quote
Old 04-05-2019, 11:16 AM   #2
Have you done any work at all on the car recently?
Old 04-05-2019, 11:20 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Have you gotten it tuned for that intake and throttle body?
Old 04-05-2019, 11:23 AM   #4
Diz86x
Not at all
Old 04-05-2019, 11:23 AM   #5
Diz86x
OFT Tuned !
Old 04-05-2019, 11:29 AM   #6
DarkPira7e
DarkPira7e's Avatar
Originally Posted by Diz86x View Post
OFT Tuned !
Have you checked to make sure the intake couplers aren't loose?
Old 04-05-2019, 11:35 AM   #7
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
OFT Tuned !
You do any logging on your oft? You can use that to help narrow down the search. Fuel trims, IAM, knock correction to start. I'm sure there are a few others that I'm forgetting about.
Also, how's the oil and coolant?
Old 04-05-2019, 11:45 AM   #8
Lantanafrs2
Drives: 2013 frs red
Sounds like something is loose
Lantanafrs2 is offline   Reply With Quote
Old 04-05-2019, 12:05 PM   #9
I am with these guys. That is why I wondered if any work had been done recently. Make sure that all clamps, bolts and fasteners are tight.
Weird Electrical Issue Relogical Issues | Warranty | Recalls / TSB 0 04-19-2018 02:09 PM
Weird OFT issue omfg5041 Software Tuning 2 12-05-2016 11:53 AM
Weird issue with my 13' Subaru BRZ Dico Issues | Warranty | Recalls / TSB 11 02-08-2016 10:37 AM
Weird site issue Impureclient Site Announcements / Questions / Issues 14 06-18-2015 04:40 PM
weird issue after BPB & OFT install DAN_BRZ Engine, Exhaust, Transmission 10 06-10-2014 09:53 PM
