Old 03-12-2016, 01:48 PM   #1
omfg5041
Weird OFT issue
I have recently run into an issue. However, I'm not sure if its an issue due to my laptop or if its due to the tablet. It appears to be the tablet running into an issue.
Heres all the information that I think would be helpful. My Operating System is OSX, but i am also running Parallels. Parallels is running windows 8.1 which I have installed OpenFlash Manager 1.25.1 on it, as well as RomRaider. I have used this configuration in the past without issue. Now, when I connect my OFT, and open OpenFlash Manager, the application stops running. If I unplug the Tablet, I get an error saying "Unconfigured device, it cannot be used.". However, I used it just last night to upload a OTS tune to my car. I wanted to make some adjustments, and got that error.
I have tried uninstalling OpenFlash Manager, and re-installing it. I have also attempted to run it in compatibility mode for Windows 7, with no luck.
Any ideas on this?
omfg5041 is offline   Reply With Quote
Old 03-12-2016, 02:02 PM   #2
Susurs
Drives: GT86
I had similar behavior using VirtualBox. What I do is to connect the device before starting the VM, so the OFT is powered on. Then, I disconnect the device logically from the VM, start OFM and reconnect it again logically to the VM. I don't know which button to press in Parallels but there should be an option that let's you decide which USB device to attach/connect to the VM. HTH.
Gesendet von iPhone mit Tapatalk
Susurs is offline   Reply With Quote
Old 12-05-2016, 11:53 AM   #3
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
Thanks for this tip. I tried a bunch of stuff thinking it was my VM causing issues with the identifying of the device (brand new device and already was able to flash my car so I knew the device was fine), but I didn't even think to connect the device to the mac first and then to the VM box. In Parallels the disconnect/connect feature is in the Menubar > Devices > External Devices.
Pointmutation is offline   Reply With Quote
Weird hot start issue mike the snake Software Tuning 21 01-18-2021 07:03 PM
Weird issue with my 13' Subaru BRZ Dico Issues | Warranty | Recalls / TSB 11 02-08-2016 10:37 AM
Weird site issue Impureclient Site Announcements / Questions / Issues 14 06-18-2015 04:40 PM
Weird issue with oft not reading cel fenton Software Tuning 7 09-14-2014 12:26 PM
weird issue after BPB & OFT install DAN_BRZ Engine, Exhaust, Transmission 10 06-10-2014 09:53 PM
