Old 03-27-2019, 07:16 PM   #15
gravitylover
Haha they make it look and sound so simple
https://demos.starbase7.net/t3Portal..._rm_index.html
The Following User Says Thank You to gravitylover For This Useful Post:
Ultramaroon (03-27-2019)
Old 03-27-2019, 07:29 PM   #16
Do you want me to send Bubba's son over to get that off for you?
Old 03-27-2019, 08:20 PM   #17
gravitylover
Hahaha
humfrz (03-27-2019)
Old 03-27-2019, 08:40 PM   #18
Originally Posted by gravitylover View Post
It's a piece of cake until that first salty New York winter. Then the whole plan goes to shit.
jcw99 (03-28-2019)
Old 03-28-2019, 09:38 AM   #19
gravitylover
After 5 of them...
Ultramaroon (03-28-2019)
Old 03-28-2019, 07:03 PM   #20
So, are you making progress?
Old 03-28-2019, 08:46 PM   #21
gravitylover
Done! Another couple of hours of pounding with big hammers and cold chisels behind the backing plate got 'er done. I had a mobile mechanic come by to teach me how to remove (and reassemble) the parking brake and he brought a bfh and large chisel. We got the whole assembly off then took it to the bench and beat the bearing carrier out of the plate.
https://imgur.com/a/W8EwEvB
The surprising thing was the rust that was holding it in is the only rust in that area of the car. The entire assembly is clean and dry, other than some surface corrosion the suspension bits are in great shape. I do need a bit of touch up paint for the wide swings with the hammer around the wheel well though
Old 03-28-2019, 09:57 PM   #22
Done! Another couple of hours of pounding with big hammers and cold chisels behind the backing plate got 'er done.(
Now you know!
gravitylover (03-29-2019), jcw99 (03-30-2019)
Old 03-28-2019, 10:48 PM   #23
clip on the rear shoe is upside down. -5
Old 03-29-2019, 09:27 PM   #24
gravitylover
Haha yeah. I'm going to pull the rotors off soon and get them turned anyway. They look like shit and don't have many miles on them since I changed the pads and rotors. I think I got some crap stuck on the passenger side and have a sticky piston on the drivers side. A little tlc is in order. When I pull that side I'll flip that clip over just because it bothers you
Old 03-29-2019, 10:29 PM   #25
lol. You're too kind.
edit: As long as we're on the subject, I used to get rotors turned too. These days, I suggest installing fresh ones. They aren't much more expensive, and maximum width of the rotor means minimum extension of the pots. It's probably trivial benefit but I feel good about it.
gravitylover (03-30-2019), humfrz (03-29-2019), jcw99 (03-30-2019)
Problem with car around 4K rpm Scion1738 Issues | Warranty | Recalls / TSB 13 11-27-2015 11:59 PM
Problem with OFT Harry04 Software Tuning 3 06-18-2015 07:35 PM
DRL problem benlaz88 Scion FR-S / Toyota 86 GT86 General Forum 23 09-19-2013 08:58 PM
Has anyone have this problem....... CSI:86 Issues | Warranty | Recalls / TSB 29 06-17-2013 09:29 AM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
