| DIY (Do-It-Yourself) Guides For all DIYs. |
So I've got a little problem
I was replacing my rear hubs because the bearings were shot and it was roaring above ~30mph. The passenger side went pretty smoothly but the drivers side didn't. When I went to pull the hub it came apart rather than coming out so now the back half of it is stuck and not going anywhere.
I've tried pretty much everything I can think of including putting some long bolts in from the back side (as if to hold the hub in) but left them pretty loose and hit them with an electric 15# hammer to try and break it loose where it's pressed into the e-brake assembly backing plate. That, and using a heavy slide hammer from the front, has been wholly unsuccessful. The car is stranded on jack stands in my driveway and I'm pretty much at my wits end. If I knew how to release the e-brake cable and remove the assembly I could press it out fairly easily but I can't seem to make that happen. The other side it came off with the hub and then a couple of taps released it from the backing plate. Help...
@Ultramaroon maybe
#3 | |
not playing cards
Good thing you PM'ed me. Mention failed.
#4 | |
That might work - for sure.humfrz |
I tried a few different ways of posting pics and it didn't work, I haven't been able to post pics here in a long time. I'm just dumb that way.
https://imgur.com/a/B7uvBqK Yeah I've tried heat, big hammer even a 15# electric impact hammer. That bugger just likes where it lives. I went way above my pay grade on this one and without knowing how to pull the axle or remove the parking brake assembly I can't get enough room to get in there and wail on it safely. Last edited by gravitylover; 03-26-2019 at 10:23 PM. |
[insert cool phrase here]
Drives: BRZ Premium
Oh... well time to get a chisel, sledge hammer and a torch.
Give it the full trump on brown people treatment. Lol.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Drives: LS Swapped Scion FRS = 440HP
My first thought is to continue with a sledge hammer with an extension to the OEM bolts from the back side. But you already tried that.
My next thought would be to remove the entire hub from the car- off the control arm, toe arm, etc. take it to a bench and try again. Find a shop with a press maybe.
not playing cards
The hand brake is easier than you think. Pull those two clips on the sides and the whole thing pops apart. You can use the other side as an example of how to connect the springs when it's time to put it back together.
You'll have to disconnect the bearing housing from the back plate. Then you'll need a deep fucking wheel puller get claws behind the housing. You may not need one as beefy as this harbor freight special but you get the idea. [ame]https://www.youtube.com/watch?v=_sbLV8N0-Hc[/ame]
#9 | |
If I could get the bearing housing to disconnect from the backing plate I wouldn't be in the situation I'm in. That's similar to the puller I used that pulled the hub apart in the first place. At this point there is nothing on the hub shell for a puller to grab anymore. If there was one that I could use the 4 bolts to hold on and then it would press against the suspension parts it would work but that's the opposite of how they all seem to attach. |
#10 | |
not playing cards
edit: Now that I took another good look, I remember something similar. That's it. Need to get between the two with a chisel. Just a screwdriver, really. Once you get it started, it'll be quick. Work your way around so it doesn't get jammed crooked.
#11 |
I reckon you tried spraying the area with PB blaster (or something like that).
Back in the day, I used to douse the area with coal oil, then after an iced tea, hit it with a BIGGER BFH. OK,OK, I'll admit, sometimes that brought on a trip to the welding shop - ![]() humfrz |
#12 | ||
Uh huh. On these modern newfangled things that look similar to the cars of old it's not always so simple to get that repaired, it's more likely you're getting bent over and getting a new part which is usually several new parts after you're done with the bushings and such. What a pita this 'simple' repair turned out to be... |
#13 | |
not playing cards
#14 | |
![]() Back in the day, you just unscrewed screws and took off nuts and bolts, that you could see, until the part fell off. Now days they have all these hidden, clips, clamps, slots and thingahmagigs, that aren't really meant to come off without breaking them - ![]() And don't get me started on all of this plastic shit they use to make things these days! I suggest more heat and a bigger hammer - ![]() humfrz |
| Problem with car around 4K rpm | Scion1738 | Issues | Warranty | Recalls / TSB | 13 | 11-27-2015 11:59 PM |
| Problem with OFT | Harry04 | Software Tuning | 3 | 06-18-2015 07:35 PM |
| DRL problem | benlaz88 | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 09-19-2013 08:58 PM |
| Has anyone have this problem....... | CSI:86 | Issues | Warranty | Recalls / TSB | 29 | 06-17-2013 09:29 AM |
| A bit of a problem | Gost | Other Vehicles & General Automotive Discussions | 13 | 02-12-2013 07:07 PM |
