Old 03-17-2019, 03:26 AM   #15
Originally Posted by rustymuffler View Post
I finally got the car back from the dealership today and as it turns out, both the front and rear passenger side wheel bearings had gone bad. Covered under warranty with 7k miles left to go. Hopefully the drivers side bearings go bad now or hold out for a while longer...
Welp, glad you got your car fixed.
Now, do you want to tell us about the time you slid into that curb?
gravitylover (05-02-2019), Ultramaroon (03-17-2019)
Old 03-17-2019, 08:11 PM   #16
Silverz
Drives: Black frs
You must have had some other issues like alignment problems, etc for that to happen so quickly.
I had one wheel bearing go bad in my last car and I did a u-turned and slid over to the other lane. No cars were around and no damage but scared me to death.
Silverz is offline   Reply With Quote
Old 03-17-2019, 11:45 PM   #17
rustymuffler
I think the only curb that the passenger wheels would have seen is during parallel parking. But that only happens once in a blue moon.... I swear!
rustymuffler is offline   Reply With Quote
The Following User Says Thank You to rustymuffler For This Useful Post:
humfrz (03-17-2019)
Old 03-17-2019, 11:52 PM   #18
OK, I got the picture -
Old 03-17-2019, 11:57 PM   #19
rustymuffler
I should have mentioned there’s 7k left in the 100k mile powertrain warranty, so I figure 93k miles out of them isn’t too bad.
you mean the wheel fell off? Sounds pretty scary, I’m glad you made it out ok!
Old 03-18-2019, 12:04 AM   #20
rustymuffler
So that’s how you get a Camry dent...
https://jalopnik.com/the-incredible-...ent-1785413530
The Following 2 Users Say Thank You to rustymuffler For This Useful Post:
humfrz (03-18-2019), Ultramaroon (03-18-2019)
Old 03-18-2019, 01:58 AM   #21
That's good. I've seen several, never knew they had a "name" -
Old 05-01-2019, 11:10 PM   #22
Silverz
Drives: Black frs
No. The bad wheel bearing locked up so only one one front wheel turned and it was a rear wheel drive so the car slid over into the other lane.
Scared the crap out of me.
Old 05-01-2019, 11:45 PM   #23
Not judging. I've learned my best lessons the hard way but didn't it make a heluva racket for a while before it got to that point? Do you have a loud exhaust or noisy tires?
Old 05-02-2019, 12:54 AM   #24
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Do you have a camber that made them go bad ? Curious to know how they both went bad ?
mswbrz is offline   Reply With Quote
Old 05-02-2019, 01:28 AM   #25
ZionsWrath
Thanks
ZionsWrath's Avatar
Do you have extended warranty? Didn't think wheel bearings were part of powertrain warranty?
Old 05-02-2019, 11:21 AM   #26
Silverz
Drives: Black frs
It wasn’t making the loud rumbling sound yet or I wasn’t paying attention. It was on my 350z which was a loud car and had a bad toe in alignment problem from the factory which I think caused the wheel bearing to go bad. Got two sets out free tires out of it because the dealer couldn’t get the alignment right.
The Following User Says Thank You to Silverz For This Useful Post:
Ultramaroon (05-02-2019)
[HELP] Rear Wheel Bearings VITA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 10-14-2019 01:58 AM
Performance wheel bearings MassTroy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-24-2018 12:03 PM
Oem rear wheel bearings+oem inner tie rods Integramike94 Brakes, Suspension, Chassis 7 09-25-2016 05:48 PM
Wheel bearings sealed? Grease? swarb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 06-10-2016 10:08 AM
Are our wheel bearings and bushings sealed or are we able to grease them up ? ScionFR-S Issues | Warranty | Recalls / TSB 4 01-28-2014 08:49 PM
