Old 03-23-2018, 12:29 PM   #1
MassTroy
Subaru BRZ
MassTroy's Avatar
Drives: 2013 Subaru BRZ
Performance wheel bearings
Last time I was working on my car I noticed that my front wheel bearings seemed very stiff and kinda noisy (they "whir" when you spin them). Someone at the shop suggested that I replace them with some higher performance bearings.
Apparently high temperatures on track can cause the spacers between the balls of the bearing to decay. Performance wheel bearings are designed with materials which can withstand the heat.
Has anyone needed to do this on their cars? Any recommendations on which product to buy or tips on how to install them?
MassTroy is offline   Reply With Quote
Old 03-23-2018, 01:23 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The front hubs are not serviceable on our cars. I just bought extra hubs off wreaked cars on craigslist. My favorite local track is hard on the right front and I have had to replace a hub on my car already.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Leonardo (03-23-2018)
Old 03-23-2018, 01:54 PM   #3
MassTroy
Subaru BRZ
MassTroy's Avatar
How many miles and how many track days do you have on the car? Mine is 60k miles and like 12 track days.
Old 03-23-2018, 03:01 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I bought the car used almost 3 years ago with 29k on it. It had a bunch of parts on it that leads me to believe it was autoX by the previous owner. At 60K now and 8 track days before I noticed the front right had a crunchy spot in it. Kind of wish I would have kept the bad hub to see if I could get it apart.
Old 03-23-2018, 04:12 PM   #5
jamal
jamal's Avatar
Drives: Legacy GT
I'm not aware of such a thing for these cars. But the bearings/hubs are easy to replace especially up front- they are a complete unit that bolts to the upright.
jamal is offline   Reply With Quote
Old 03-24-2018, 12:03 PM   #6
MassTroy
Subaru BRZ
MassTroy's Avatar
I just contacted CSG and they said there aren't any high performance wheel bearings for our cars on the market but the OEM system is pretty good. Not sure why I've seen a few wear out so quickly
track build, wheel bearing
[HELP] Rear Wheel Bearings VITA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 10-14-2019 01:58 AM
Oem rear wheel bearings+oem inner tie rods Integramike94 Brakes, Suspension, Chassis 7 09-25-2016 05:48 PM
Wheel bearings sealed? Grease? swarb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 06-10-2016 10:08 AM
Are our wheel bearings and bushings sealed or are we able to grease them up ? ScionFR-S Issues | Warranty | Recalls / TSB 4 01-28-2014 08:49 PM
Performance and wheel size Howardwei Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-05-2013 11:11 AM
