#155 | |
Only users lose drugs.
Drives: All the time
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#156 |
Drives: Frs
ive got a tanabe concept G, was 92db with stock header/FP...jumped to 99-100 db with catless header/resonated FP
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
| The Following User Says Thank You to Submarinesonce For This Useful Post: | Tristor (03-21-2018) |
#157 | |
Drives: 2015 BRZ Limited
#158 |
102 vs 88 is a lot...
#159 |
Drives: 2014 GT86
10 dB is difference between perceivable volume of twice louder (and 20dB accordingly four times louder).
14 dB of 102 vs 88 .. i guess ~ 2.6x subjectively louder? Scale of sound volume numbers sometimes seem subjectively misleading (i guess, probably due relatively small numbers, one is often used to associate in subconsciousness with eg. percents or amount of something material). Difference between 35 dB and 45 dB may seem bigger then between 110 and 120 dB due relative "number" difference, when in reality both are jumps of doubled subjective loudness vs quieter one. |
#160 | |
Drives: brz 2017 hksv2
it's a delicate topic, there is more involved in it that would need to be involved as well, like a frequency analisys |
#161 |
Anyway, 102 dB is not so quiet as there are JDM catbacks declared as 90-92 dB, as JASMA needs (sound level legal emission test).
#162 |
#163 |
Fujitsubo, Blitz, Tom's and Kakimoto seem to be the quietest.
#164 |
Drives: 16' BRZ
This is easy. The quietest is the stock muffler and the loudest is a cutout before the muffler. I highly recommend this setup, best of both worlds sound wise and you get little to no performance gain from a catback.
| Exhaust System/Exhaust Manifold Removal and Replacement | GrimmSpeed | DIY (Do-It-Yourself) Guides | 52 | 11-11-2015 09:30 PM |
| Injen exhaust system | JoeBoxer | Engine, Exhaust, Transmission | 5 | 02-28-2013 01:43 AM |
| Lightest/quietest exhaust system out there | GTB/ZR-1 | Engine, Exhaust, Transmission | 25 | 10-31-2012 12:45 AM |
| What is the best exhaust system for the FT86 | LOTUS86 | Engine, Exhaust, Transmission | 4 | 07-31-2012 02:36 AM |
| TRD Exhaust System... | Griffdawg | Engine, Exhaust, Transmission | 2 | 07-18-2012 12:27 AM |
