Old 03-08-2019, 10:35 PM   #1
rustymuffler
Wheel bearings gone bad
I’ve got a 2013 brz that’s got all the symptoms of a bad wheel bearing (vibration at low speed, clicking/creaking while turning, roar at 50mph) and I’m curious if anyone who has had a wheel bearing go bad got it covered without hassle under warranty. I have 7k left of my 7y/100k CPO, but when I brought the car to the dealer in October they said they couldn’t replicate the sounds. I’ll be bringing it in on Monday, any advice on how to get the dealer to listen?
rustymuffler is offline   Reply With Quote
Old 03-08-2019, 10:45 PM   #2
Welcome to the forum, rustymuffler …
I suggest you take the tech for a ride and demonstrate what your car is doing.
A bad wheel bearing is pretty easy to detect - when the car is moving, briskly turn the wheel back and forth - does it make a clunking sound? Jack up the car, grab hold of the wheel and move it back and forth, does it feel lose?
Old 03-09-2019, 12:51 AM   #3
rustymuffler
Thanks for the welcome humfrz! That’s a good idea I’ll see if the technician can ride along.
Turning the wheel causes a creaky clicking sound at parking lot speeds, above that it’s hard to tell. With the car jacked up the wheel doesn’t really feel loose, but hard to tell with the play in the steering rack.
The most obvious is it sounds like there’s a second engine in the car at highway speed..
The Following User Says Thank You to rustymuffler For This Useful Post:
humfrz (03-09-2019)
Old 03-09-2019, 02:06 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It is really hard to tell without some disassembly. I had to jack my car up, remove brake pads, put the wheel back on, turn the wheel while applying more pressure to one side, you really need to load it some what while turning it to tell if it has a bad spot. I had a dull roar coming from mine and ended up replacing the front right, which should be no surprise that one went first considering most tracks I have been to run counter clockwise.
Old 03-10-2019, 01:56 PM   #5
rustymuffler
So I jacked the car up, and spun the wheel as fast as I could by hand, and even though I didn’t remove the brakes I could hear a bearing race noise, and a low hum. Interestingly also on the front right...
Old 03-10-2019, 03:52 PM   #6
Welcome, Rusty. Yup. Bearings are toast. If you can, take it to another dealer who will listen to you. :/
They should run dead silent but I think you already know that.
Old 03-10-2019, 04:23 PM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
I have a spare (used, low miles) rear wheel bearing if you are interested. Let me know.
Old 03-10-2019, 04:47 PM   #8
rustymuffler
Thanks Ultra. To be fair to the dealer it has become 10x worse since I brought it last, hopefully they will hear it this time around.
Old 03-10-2019, 04:54 PM   #9
rustymuffler
Thanks ZionsWrath, I’ll keep that in mind if either rears need replacement and aren’t honored under warranty
Old 03-10-2019, 05:25 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Subaru rear wheel bearings are a pain in the ass. I lost a front which is a unit hub. 4 bolts after pulling the wheel and brake.
Sent from my Moto E (4) Plus using Tapatalk
Old 03-11-2019, 09:21 AM   #11
gravitylover
My rear bearings are shot, the noise is getting worse but damn it's expensive to get them replaced. The car is doing more sitting than anything else now because of that.
Old 03-11-2019, 03:46 PM   #12
For anyone considering DIY-ing the rear bearings, here's a quick tip.
The reluctor wheel is attached to the axle shaft outboard of the sensor. The wheel speed sensor must be removed before pulling the axle shaft. Otherwise, both it and the reluctor will be destroyed when they interfere with each other.
NoHaveMSG (03-11-2019)
Old 03-11-2019, 05:12 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
And don't forget to put the reluctor ring on the hub before pushing the hub through the inner race.
Ultramaroon (03-11-2019)
Old 03-16-2019, 08:13 PM   #14
rustymuffler
I finally got the car back from the dealership today and as it turns out, both the front and rear passenger side wheel bearings had gone bad. Covered under warranty with 7k miles left to go. Hopefully the drivers side bearings go bad now or hold out for a while longer...
humfrz (03-16-2019)
[HELP] Rear Wheel Bearings VITA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 10-14-2019 02:58 AM
Performance wheel bearings MassTroy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-24-2018 01:03 PM
Oem rear wheel bearings+oem inner tie rods Integramike94 Brakes, Suspension, Chassis 7 09-25-2016 06:48 PM
Wheel bearings sealed? Grease? swarb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 06-10-2016 11:08 AM
Are our wheel bearings and bushings sealed or are we able to grease them up ? ScionFR-S Issues | Warranty | Recalls / TSB 4 01-28-2014 09:49 PM
