#99 | |
Weight Weenie
Drives: 15 FR-S
I'm looking at this piece myself. The drivers side is supported by the plastic, which supports the OBD2. I want to have another look and see if it offers a tapped whole for the plastic on the passenger side. |
#100 | |
Drives: 2013 scion fr-s
Just stumbled upon this forum post of some dude's incomplete 7 year project of building the lightest possible porche, basically from scratch. A lot of drilling out the tiniest parts, thought it might provide some inspiration: http://forums.pelicanparts.com/porsc...d-projekt.html |
| The Following 3 Users Say Thank You to q335r49 For This Useful Post: |
#101 | |
Weight Weenie
Drives: 15 FR-S
I have the dash out now. I haven't put it on a scale but it's surprisingly heavy. It's fairly easy to get out. It's going back in for now. The drilling thing doesn't add up to much... but why not. Replacing steel with aluminum or carbon in non structural areas will get better gains. If I reproduced the rad support in aluminum I would have lost around 1.5lb. I'll be looking at that some day. It's weights 1,111g/2.44lbs stock. Thanks, I've seen that thread. There's another on that forum I've read. I'll try and find it and post it here. Edit: here's the other thread I was talking about http://forums.pelicanparts.com/911-9...st-combat.html Last edited by new2subaru; 02-25-2019 at 07:28 AM. |
#102 |
Those porche boys are something else. I tried my best to channel swiss machinist but came up short, nonetheless, it was an interesting project.
I didn't have a shipping scale so no idea how much I took off. I had my center console removed so I added a foam elbow rest. I also entirely removed a third support leg/screw, which I had been leaving unbolted for awhile anyways and figured it wasn't essential. It definitely flexes more than it used to when you pull hard on it. Maybe I'll leave it in gear for awhile lol. ![]()
| The Following 2 Users Say Thank You to q335r49 For This Useful Post: | new2subaru (02-27-2019), SuperTom (01-05-2020) |
#103 | |
Weight Weenie
Drives: 15 FR-S
It looks good!. There's a couple of spots where you left the edges a bit thin but other than that your "swiss machinist" skills are there
| The Following User Says Thank You to new2subaru For This Useful Post: | q335r49 (02-27-2019) |
#104 |
Drives: C5, GT-86, '24 Colorado TrailBoss
Damn Great work I didn't think of swiss cheesing the ebrake!
| The Following User Says Thank You to SuperTom For This Useful Post: | q335r49 (02-27-2019) |
#105 |
Only happy when it rains.
Drives: series.blue
this thread has really become awesome.
#106 | |
Im in process of swiss cheesing my ebrake with a hundred tiny holes. It looks like you took yours apart to get to the thick steel behind the pivot area. What did you use to put it back together?? looks like you got some nice shiny brass of whatever those rivets are called |
#107 |
Whats your favorite type of cheese?
Mine is Swiss Cheese! A lot of work to save .5 lbs but it was free Found it easier to drill smaller holes than bigger holes through the Steel it also keep material around each hole Original is 3lbs 1oz, got it down to 2lbs 9oz ![]() ![]()
| The Following 2 Users Say Thank You to SuperTom For This Useful Post: | MaverickMonk (01-27-2020), ML (01-25-2020) |
#108 |
Drives: 13 White MT FR-S
If you were really committed to weight savings you would remove your ebrake completely and save a good amount of weight with the drum brake gone. Just park in gear and maybe carry a chock around. Small piece of wood is probably only a few ounces. I’m only half joking here
#109 | |
I also thought of removing all the drum brake stuff and just adding a second caliper just for ebrake. Not sure if it would be lighter but would allow for an aluminum drum hat if I could get someone to make 2pc stock sized rotors |
| The Following 2 Users Say Thank You to SuperTom For This Useful Post: | MaverickMonk (01-27-2020), ML (01-27-2020) |
#110 |
Drives: Track preped NA FRS
Also, for those that do the pedal dance, the ebrake is necessary. Otherwise you need something like the nanny86 or some similar device to enable it.
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | ML (01-27-2020) |
#111 | ||
Drives: 13 BRZ Limited
#112 | |
Yeah I read through that whole build. He also had a lot of custom titanium parts made as well. Ive just bought a punch and flare tool to do some experiment on non structural metal... |
| Making the BRZ ever lighter | Alabang BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 04-16-2014 08:57 AM |
| Are dry carbon fiber front 1/4 panels lighter than OEM? | Superhatch | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-27-2013 03:47 AM |
| Better to go wider or lighter? | BRAWL | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 08-02-2012 09:48 PM |
| Increased whp by having lighter wheels | mechaghost | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 07-03-2012 12:46 AM |
| What return from going with lighter wheels? | bazguitarman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 06-01-2012 09:35 AM |
