Old 02-23-2019, 03:51 PM   #15
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Originally Posted by RZNT4R View Post
I'm no expert in US weather, but you might be having some brake seizing issues if they've never been dismantled, cleaned and had brake lube applied appropriately. Winter is ROUGH, and road abrasives and salt are ROUGH on disc brakes. Here in Quebec, most disc brake pads that have been lubed will seize solid in the rack in about a year in a half if they're left alone. Considering most cars leave the dealer lots with completely dry brakes, it wouldn't be a surprise to see them starting to jam within a year after they're put in service.
Not sure what kind of weird, caustic chemicals they use up in Quebec, but no new car should have brakes seizing up after just one winter, no matter how salty it gets...
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
FRSBRZGT86FAN (02-23-2019)
Old 02-23-2019, 04:58 PM   #16
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
That's the sad reality though.
The Following User Says Thank You to RZNT4R For This Useful Post:
Ultramaroon (02-23-2019)
Old 02-23-2019, 05:57 PM   #17
maslin
Benz Tech
Drives: 2017 BRZ Premium
I’m with you. 15 years in the automotive industry I’ve seen maybe 10 seized calipers. Never seen pads seized “in the rack”, not once. Plenty of real winters between Virginia, Montana and Oregon.
maslin is offline   Reply With Quote
Old 02-23-2019, 06:25 PM   #18
RZNT4R
Having to hammer pads out of a rack is a regular occurrence, having rotors rusted to the hubs so hard you've got to shatter them with a sledgehammer isn't even rare. Most things require the oxy acetylene torch to be removed. That is my life.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
gravitylover (02-23-2019), Tristor (02-23-2019)
Old 02-23-2019, 07:37 PM   #19
nico_rsx
Drives: BRZ 2017 Pure Red, MT
I've seen easily more than 10 seized calipers and I dont even work in the auto industry
It happens to me at least on 2 occasion Not on a brand new car tough.
nico_rsx is offline   Reply With Quote
Old 02-23-2019, 07:51 PM   #20
Stang70Fastback
A.K.A. Starlord
I've had a seized caliper before. It was because the car was 15 years old. I stand by the fact that a properly manufactured and maintained new vehicle shouldn't have parts failing as a result of salty winters in 1-2 years. OEMs test for this. Calipers have grease and rubber boots on the slider pins.
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
FRSBRZGT86FAN (02-24-2019), Ultramaroon (02-23-2019)
Old 02-23-2019, 09:00 PM   #21
If a boot gets the smallest nick, it's goodbye. I've personally seen it happen on a new-ish car. Rare for a new one but not out of the question. Doesn't take long for the corrosion to set in.
edit: Pucks in the caliper, though? I've seen them jam and wear crooked. Once they start going south, the caliper jams too.
Old 02-24-2019, 08:38 AM   #22
RZNT4R
They don't jam on the slide pins, rust builds up between the racks and abutment shims, seizing the pad in place.
Old 02-24-2019, 09:23 AM   #23
Stang70Fastback
A.K.A. Starlord
I've never had that happen either, but I have always properly greased my pads when I install them. I assume the factory does the same. My BRZ has gone through many winters without issues.
Old 02-24-2019, 02:09 PM   #24
Factory brake pads are installed bone dry. At least mine were. I'm still on the originals after 50 K.
Old 02-24-2019, 03:03 PM   #25
Stang70Fastback
A.K.A. Starlord
Well my factory brakes survived 3 winters in Chicago with no issues
Ultramaroon (02-24-2019)
Old 02-24-2019, 09:18 PM   #26
gravitylover
I got about 90k on the rears and ~105 on the fronts.
The Following User Says Thank You to gravitylover For This Useful Post:
Old 02-24-2019, 09:25 PM   #27
That's nice balance for wear. Impressive.
gravitylover (02-25-2019)
Old 02-24-2019, 10:43 PM   #28
sato
sato's Avatar
Drives: Dodge Patitas
I'm almost at 100k and haven't changed anything. Looking forward to it though, since it seems my rotors are a bit warped (very noticeable when a bit of water splashes around).
sato is offline   Reply With Quote
Any solutions to overheating coilpacks? Turbo Tracking / Autocross / HPDE / Drifting 11 12-21-2018 11:36 PM
whole lot of weirdness/possible overheating shaynek Issues | Warranty | Recalls / TSB 7 08-01-2018 06:56 PM
Overheating stick shift sj30jet Engine, Exhaust, Transmission 8 06-12-2017 01:03 PM
BRZ overheating Notso BRZ First-Gen (2012+) — General Topics 67 06-25-2016 12:01 PM
Massive Overheating Incident mitosis Issues | Warranty | Recalls / TSB 26 11-18-2013 07:12 AM
