Old 02-19-2019, 09:34 PM   #1
lilred
Drives: 2013 FRS
LOCATION OF BOV?
Hello everyone,
I have a HKS Supercharger installed and I'm having a hard time finding the BOV. If possible can someone please link a photo of where its located or maybe a link to a video showing where its at? Having problems I need to address and I want to start there!
Thank you!
lilred is offline   Reply With Quote
Old 02-19-2019, 10:16 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Isn't it the large wart on your intake piping near the throttle body?
Old 02-19-2019, 11:33 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Superchargers don't have BOVs.
Turbos do, some are optional.
Also your google-fu is weak young grasshopper.
Old 02-19-2019, 11:43 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Looks like it is the little manifold about 6 inches away from the TB
http://www.ft86club.com/forums/showp...3&postcount=89
Old 02-20-2019, 02:37 AM   #5
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Well, well,
Old 02-20-2019, 03:49 AM   #6
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
HKS supercharger has bypass valve.
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
Old 02-20-2019, 03:56 AM   #7
tomm.brz
Drives: brz 2017 hksv2
To make everyone happy, it's a very basic BOV that has a function of bypass valve during lift off accelerator pedal in this kit
Old 02-20-2019, 09:39 AM   #8
DarkPira7e
DarkPira7e's Avatar
Well, well,
Yeah, pretty sure HKS put it on there just because it makes noises. I only knew because a friend of mine was looking into buying this kit and I couldn't believe it was there. Can't fault you
Old 02-20-2019, 10:40 AM   #9
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Definitely not always the case. You see people put BOVs on centrifugal kits all the time. Some kits even optional bigger / better versions. (vortech maxflow etc) Almost all types have a bypass valve of some kind now, even OEMs.
The BPV setup like that doesn't really make the traditional BOV noise. Its recirculating the air back in to the intake tract as opposed to venting it to the atmosphere.
Old 02-20-2019, 11:29 AM   #10
DarkPira7e
DarkPira7e's Avatar
I guess I meant to infer that people will swap it out to make noise
Old 02-20-2019, 11:49 AM   #11
tomm.brz
Even if you swap it, you must recirculate it so bigger BOV won t be so noisy
One should drill the charge pipe and put the maf there just before the throttle body to be able to vent it to atmosphere, like Vortech centrifugal kit
it's there to do its job, to relief pressure during throttle off events
Old 02-20-2019, 02:34 PM   #12
Grady
Grady's Avatar
BOV and Recirculated valves do the same thing. One makes noise one does not. In order to do a BOV correct you will need to relocate the mas air flow sensor to after the BOV.
Old 02-20-2019, 02:52 PM   #13
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Well, well,
Guess your Google-Fu is weak too :p
MS, CSCS, TSAC-F, CPT
Old 02-20-2019, 05:38 PM   #14
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Lol every now and then the student can land a punch on the master.
Amp Location? FNCrazy Electronics | Audio | NAV | Infotainment 10 07-09-2016 10:54 AM
BOV location? teddydoggy Forced Induction 2 09-17-2015 09:09 AM
New Name and Location but same service. Hamza7 CANADA 10 03-06-2014 01:04 PM
Looking for a vendor location Vincenttam Want-To-Buy Requests 2 02-21-2014 12:49 AM
ECU box location?? RehabJeff86 Electronics | Audio | NAV | Infotainment 2 09-18-2013 03:34 PM
