#15 | |
Drives: BRZ 2018
I contacted more than twice local dealer but they can't find the correct part number for the rearview camera so if we share the same system could you tell me the part number please? |
#16 |
I live in Italy, but I own an 86. Camera is just for JP and US versions. Not an issue, it can pair with other systems, it just needs 6V for feeding (you can use a 7806 chip). P/N is 86267CA500.
| The Following User Says Thank You to gpvecchi For This Useful Post: | JIM THEO (09-18-2018) |
#17 |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
Here is how the factory mounts the reverse camera in my (dirty) Series.Yellow
#18 |
Could you please measure the distance between the bottom of the trim and the lower edge of the camera plate? Thanks!
#19 |
~1.1cm from the bottom of the trunk garnish to the edge of the camera plate.
~0.8cm from where the trunk garnish light cutout begins to the edge of the camera plate. ![]()
| The Following User Says Thank You to dhuang For This Useful Post: | gpvecchi (09-20-2018) |
#20 |
Great, many thanks! This is very very useful!
#21 |
Drives: 2015 Subaru BRZ in WRB
Sorry to hijack, but besides the OEM camera, what did u use for the wiring?
#22 |
As I used an aftermarket radio, I cut the 4 pin connector of the camera and soldered a female RCA and a 7806 chip to feed 6V. Then I connected a couple of wires to reverse lights, and a male to make 75 Ohms RCA to the monitor.
BTW, the trunk trim is pre cut. |
#23 |
Ah i see. I think that might be out of my depth to attempt.
Thanks for the reply! |
#24 |
Drives: BRZ 2018
#25 |
Rear OEM camera is just for US and Australian market. If you have an aftermarket radio, my solution is the best. If you have stock one, you need to buy the trunk (and probably other) wiring, as there is no cord from factory. Or you can buy a genuine Subaru aftermarket camera.
#26 | |
Drives: BRZ 2018
#27 | |
#28 |
Really? UK has it? I read the 2017 technical bulletin and it wasn't mentioned, just US and AU... Are you sure yours isn't the Subaru aftermarket?
| Backup Camera input/recommendations for 2014 Monogram without factory Backup Camera | RedLeaderD4S | Electronics | Audio | NAV | Infotainment | 3 | 08-04-2017 08:32 PM |
| 100% Plug-&-Play Rearview Camera Installed from camera-source.com (Pics) | zthang | DIY (Do-It-Yourself) Guides | 10 | 12-18-2015 04:14 PM |
| SOLD - Rydeen Duo ZH07-150B Backup Camera and Rear Camera SVXdc Harness | NanDAssi | Audio/Visual, Electronics, Infotainment, NAV | 5 | 11-24-2015 05:06 PM |
| car camera | Wherestheweed420 | BRZ First-Gen (2012+) — General Topics | 44 | 07-23-2015 04:00 PM |
| Contour GPS Camera | Simmons | Miscellaneous | 2 | 01-28-2013 10:22 PM |
