Old 04-28-2018, 04:27 PM   #1
gpvecchi
gpvecchi's Avatar
BRZ OEM camera
I just got an OEM camera (not the OEM aftermarket, but the one that's shipped from factory).
I don't understand how to attach it to the car; do someone have some picture/hints?
gpvecchi is offline   Reply With Quote
Old 04-28-2018, 06:32 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It's all in YouTube.
If all you got was the camera, then you need the wiring harness to connect to the back of the stereo.
Old 04-29-2018, 04:04 AM   #3
gpvecchi
gpvecchi's Avatar
Thanks, but I mean how to mount it on the trunk. It has a strange plate with clips.
Old 04-29-2018, 05:04 AM   #4
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
The extra BRZ adapter "plate" wedge is to is to angle the camera to the right angle since the OEM camera is used for multiple Subaru models. The kit should already include the Pioneer pigtail wire harness.
I have one myself, installed by myself. To this day, though it was an expensive investment, it's well worth it. Quality is very good!
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 04-29-2018, 11:45 AM   #5
gpvecchi
gpvecchi's Avatar
Do you have some photos? does the plate stick to the trim or to the trunk itself?
Old 04-29-2018, 03:41 PM   #6
DaJo
FT86Club Vancouver
DaJo's Avatar
That's a different one from mine haha... Mine is in-cased with a black metal housing, unlike most that uses plastic...
This is the one that I have. Bought from my local Subaru dealership with Subaru parts number and everything.
2000 MR-S 5MT
2010-2012
Old 04-29-2018, 09:30 PM   #7
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
The plate goes vertically on the trunk itself, underneath the center trim piece. If your car didn't come with the camera, the cutout on the trim piece to allow it to mount won't be there, you'll have to deal with that somehow.
Keep in mind that any cutting you do on the trim to give the camera the clearance it needs won't be covered up by anything, so you'll always see whatever imperfection might be left behind. For that reason, it's much easier to get the style DaJo bought and mount it directly on the trim as it will cover any hole you drill.
sharpsicle is offline   Reply With Quote
Old 04-30-2018, 03:46 AM   #8
gpvecchi
gpvecchi's Avatar
Thanks, I saw that there are no different part numbers for both trunk nor trim. Cutting the trim is not a problem, do the trunk has the hole? This could be annoying...
Any photo, please?
Old 04-30-2018, 12:51 PM   #9
jubella2
jubella2's Avatar
Drives: DGM BRZ
There is a hole the wires for the license plate lights go through that you can run the camera wire in too.
jubella2 is offline   Reply With Quote
Old 04-30-2018, 01:18 PM   #10
gpvecchi
gpvecchi's Avatar
Guys, no offence, I worked for 10 years in car hi-fi area, I know how to fit a rear camera. I just want to know how the OEM camera is attached to the trunk, as there is no specific part number for trunk. If your car did not came with a camera from factory, that's not what I'm looking for...
Old 04-30-2018, 04:53 PM   #11
sharpsicle
sharpsicle's Avatar
You don't need different parts for the trunk or trim. Just need to modify the existing piece. If you take a look at the actual parts on the car, you'll see what I'm talking about. There are seam lines where the camera cutout would be that you need to remove. As for the trunk, there are a multitude of holes under that trim piece, but most people add new wiring through the grommet for the license plate lights as it's convenient and protected.
This may sound harsh, but if you've been in this field for 10 years you should know what you're looking at when you pop off the rear trim. Add to that a simple search for OEM cameras and you'll have no problem.
Old 05-01-2018, 03:28 AM   #12
gpvecchi
gpvecchi's Avatar
I still don’t have my car, it’ll arrive in July, and I’m going to buy all the parts I need before that date...
Old 05-01-2018, 05:50 AM   #13
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Dude. Seriously YouTube it. It's all there.
The Following User Says Thank You to Mr.ac For This Useful Post:
FRSBRZGT86FAN (02-14-2019)
Old 09-18-2018, 01:04 AM   #14
gpvecchi
gpvecchi's Avatar
I re-up this thread because I got my car. Now, I see there’s a masking on the trim piece with the cutout for the camera, but the trunk needs to be drilled.
I can find the horizontal alignment measuring the trim, but I can’t find the vertical measure. Anyone with stock camera may please take it for me?
Plus, is there any groove for the borders of the plate?
Thanks!
Backup Camera input/recommendations for 2014 Monogram without factory Backup Camera RedLeaderD4S Electronics | Audio | NAV | Infotainment 3 08-04-2017 08:32 PM
100% Plug-&-Play Rearview Camera Installed from camera-source.com (Pics) zthang DIY (Do-It-Yourself) Guides 10 12-18-2015 04:14 PM
SOLD - Rydeen Duo ZH07-150B Backup Camera and Rear Camera SVXdc Harness NanDAssi Audio/Visual, Electronics, Infotainment, NAV 5 11-24-2015 05:06 PM
car camera Wherestheweed420 BRZ First-Gen (2012+) — General Topics 44 07-23-2015 04:00 PM
Contour GPS Camera Simmons Miscellaneous 2 01-28-2013 10:22 PM
