Old 02-02-2019, 01:47 AM   #1
Alpha86
Drives: 2013 Firestorm Red FRS
Requirements For Lowering
It appears this hasn't been entirely discussed (or at least not in its own thread), but what is needed to maximize reliability when lowering? Going with the Eibach Pro-Kit (1-inch drop all around) and planning on adjustable LCAs, rear toe kit and front camber bolts. I hear lots of people damaging their swaybar end links with coilovers, does this need to be addressed as well? TIA.
Alpha86 is offline   Reply With Quote
Old 02-02-2019, 02:09 AM   #2
86MLR
86MLR's Avatar
Front endlinks to match drop.
Lowering can cause issues with the oem links both at the upper and lower joints.
This info is in this forum, more searching needed.
Old 02-02-2019, 02:32 AM   #3
fatoni
I think a lot of it depends on how low and what your objective are. I'm on some tein flex z. They seem super low to me. All I have are lcas. Maybe I could do better but I don't run into any issues on the street.
Drive upgrades. Don't buy them.
Old 02-02-2019, 08:07 AM   #4
Joveen
Joveen's Avatar
Drives: Bone stock
If your worried about endlinks, get adjustable ones.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 02-02-2019, 08:38 AM   #5
mrg666
pessimistic skeptic
mrg666's Avatar
If it is just 1 inch lowering with Eibach Pro, you don't need anything other than replacing the springs and an alignment after that.
But I would replace the shocks and struts together with the springs since your car is 2013.
Old 02-02-2019, 03:08 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
When I installed Prokit springs 65k miles ago, I wished I had also installed a Roll center bumpsteer kit. I now have the whiteline kit. The difference in feel is noticable. A nice "planted" feel. I would suggest it with the parts you have.
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Alpha86 (02-03-2019), smg1138 (02-04-2019)
Old 02-02-2019, 05:10 PM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I have the same. Zero bumpsteer.
Leonardo (02-02-2019)
Old 02-02-2019, 11:54 PM   #8
xdavidx
Emperor McDuck
xdavidx's Avatar
Drives: 2019 86 GT; 2018 BMW S1000RR
Eibach pro is the same drop as the trd springs they are a factory option and warrantied even as a dealer installed option. If Toyota doesn't even recommend anything other than an alignment, then its safe to say anything more would be unnecessary and likely a waste of money.
xdavidx is offline   Reply With Quote
The Following User Says Thank You to xdavidx For This Useful Post:
Old 02-03-2019, 12:16 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Who decided a roll center kit was not great to install with drop springs?
I LIKE TIRES!
Old 02-03-2019, 04:12 PM   #10
Gunman
Drives: 2019 Mazda Miata RF
Is it truly a "roll center" change? Most modern suspension design theory, has pushed static roll centers down the list of concerns.
Old 02-03-2019, 05:09 PM   #11
xdavidx
Emperor McDuck
xdavidx's Avatar
Can't say with certainty, but likely Tetsuya Tada; the chief engineer for the 86 at Toyota. Could have been one of the TRD engineers though too, but I doubt he was not at least consulted.
Old 02-03-2019, 06:35 PM   #12
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Mac strut needs the kit to fix the suspension geometry from lowering. Believe whatever you want though.
I LIKE TIRES!
Old 02-03-2019, 06:37 PM   #13
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The kit is a huge improvement in feel. But don't take my word for it.
I LIKE TIRES!
Old 02-03-2019, 11:57 PM   #14
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
You could skip the rear toe arms. The stock eccentric toe bolt in the rear should be able to keep you in spec with your mild drop.
tyler_win_photo is offline   Reply With Quote
The Following 2 Users Say Thank You to tyler_win_photo For This Useful Post:
Alpha86 (02-09-2019), strat61caster (02-04-2019)
Ca. Smog requirements CPO 76 BRZ First-Gen (2012+) — General Topics 18 04-11-2018 04:35 PM
requirements to run openflash manager Grip Ronin Software Tuning 22 03-11-2015 03:58 PM
Eibach Sportlines requirements Hawk77FT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 11-12-2013 12:02 AM
250 ~ 300 hp - Cost, Requirements, Effects Froylavin Engine, Exhaust, Transmission 14 07-19-2012 01:55 AM
Minimum requirements... Blokatos Scion FR-S / Toyota 86 GT86 General Forum 528 11-15-2011 05:04 PM
