Old 10-28-2013, 09:08 PM   #1
Hawk77FT
Drives: GTS 86
Eibach Sportlines requirements
Hi all,
I am getting a good deal on some Eibach Sportlines. I was just wondering what else do i need to have the correct camber. The last thing I want is inside or uneven tire wear.
From what i have read on the forum I need to go with the following:
Front - Whiteline camber bolts
Rear
- Whiteline rear camber adjustment bushing kit (KCA 326) OR lca (someone recommended SPC but I am a bit concerned about the quality of them unless I am wrong and they have changed their design (to a one solid arm).
Anyone that has done theirs? What did you install afterwards to correct the camber front and back?
Hawk77FT is offline   Reply With Quote
Old 10-28-2013, 09:38 PM   #2
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
The SPC arms are solid and have been for quite some time now.
http://www.ft86club.com/forums/showthread.php?t=38527
SPC is a solid way to go without breaking the bank.
FT-86 SpeedFactory is offline   Reply With Quote
Old 10-29-2013, 12:13 AM   #3
Hawk77FT
Drives: GTS 86
I have sent you a PM.
For the Eibach Sportline in particular would the whiteline camber adjustment do the job? or i need to go with LCA's?
Old 10-29-2013, 12:40 AM   #4
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Bushings are a pita and very labor intensive. Been there done that go LCA IMO.
Old 11-11-2013, 01:59 AM   #5
Hawk77FT
Drives: GTS 86
Ok, so I am getting the SPC lca's for the rear, SPC crusher bolts for the fronts and the KCA 435 for the front (to maintain or at least bring it closer to the geometry of the car). my question is, considering the 1.4 drop, do i need to get the rear adjustable toe arms to be able to adjust the toe to 0 or slight negative? i dont want to get an uneven tire wear and play too much with the geometry of the car.
Sportline guys out there, did you get the rear adjustable toe arms to keep the alignment within the stock limits? (or close)
Old 11-11-2013, 02:28 AM   #6
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I got 0 toe without aftermarket toe arms. I didn't even have to change the stock toe bushings to the ones that come with the SPC LCAs.
Old 11-11-2013, 05:00 AM   #7
Davesta619
Drives: Brz
I'm planning on getting sportlines too, 18" wheels staggered. I was only planning on getting the springs. Will I need to buy control arms, etc or will I be okay without them? My car is just for normal driving, no track or anything.
Davesta619 is offline   Reply With Quote
Old 11-11-2013, 07:30 AM   #8
Hawk77FT
Drives: GTS 86
How hard is to replace the toe arms?
Sent from my HTC One X using Tapatalk 2
Old 11-11-2013, 11:31 AM   #9
boredom.is.me
Custom User Title
You do not NEED the LCA, but you will be running about -2 degrees of camber without them.
You really do not need to change any part related to rear toe.
Old 11-11-2013, 05:34 PM   #10
Hawk77FT
Drives: GTS 86
Well, i dont want to run -2 degree camber really as I would like to keep the balance of the car as much as possible. With the drop, the toe is also affected which will lead to uneven tire wear which, as per my original post is the last thing I want. Lowering the car beyond the 1" will require some modifications to maintain the geometry of the suspension.
Old 11-11-2013, 05:37 PM   #11
boredom.is.me
Custom User Title
And I am telling you that I did not need to buy toe arms to zero my toe. I am at ~1 degree camber in the rear which is within factory specs.
I have SPC control arms. They come with optional toe bushings that increase the range adjustment, but they weren't needed either.
Old 11-11-2013, 05:51 PM   #12
Hawk77FT
Drives: GTS 86
Oh thanks mate,
Do you have the Sportlines on yours?
As far as I read on the forum, it seems that with the Sportlines, there is no way you could get within the factory specs without getting adjustable lca's so for SPC will do the trick! My only concern is that by going that low i might need to get the adjustable toe arms and I thought i would do it while i am at it.
Old 11-11-2013, 06:01 PM   #13
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Fuck, are you serious? Pics with LCAs and pics without?
Old 11-11-2013, 06:12 PM   #14
boredom.is.me
Custom User Title
Factory settings still has some toe, so no it isn't exactly zero, but it is at the factory setting. I could have gotten better front settings, but I forgot to install the bolts...
I do not really have before and after pics, but this is where it is at with the settings shown.
Broken post...hold on.
Anyone with Eibach Sportlines gatorbushmen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 12-12-2013 01:55 AM
FS: Brand New Eibach Sportlines FaNtaSy Australia Classifieds 2 11-16-2013 09:34 AM
RCE Yellows or Eibach Sportlines? ChandlerSwyng Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 07-21-2013 04:09 PM
NY: F/S Eibach Sportlines delusional Brakes, Suspension, Chassis 7 04-26-2013 12:35 PM
Eibach Sportlines Finally Available! PRO Import Tuners Brakes, Suspension, Chassis 1 08-22-2012 07:42 PM
