Old 03-05-2015, 06:53 PM   #1
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
requirements to run openflash manager
so im having this new issue, since ive put windows on a SSD openflash manager wont start.
i open it and it instantly says PWGPRO has stopped working. Under details the event name is CLR20r3 which ive spent weeks searching and trying things and nothing works. ive tried multiple reinstalls, regi repairs and tried installing it on other non SSD drives running on my pc with no effect. Ive tried emailing OFT team but got no answer. So im wondering if im missing some program that is needed to run this like java,adobe, c++ .net framework? (i have all of these installed btw)
IG-Joey_Soul
Old 03-05-2015, 07:09 PM   #2
DAEMANO
Time Traveller
Try backing up, then deleting your OpenFlashManager folder, then redownloading OFM and re-installing. Otherwise IDK.
OpenFlashManager seems to run with no probs on everything I've put it on. This includes a very low spec'd 7" Winbook TW700 tablet running Windows 8.1 (1GB RAM 16GB MMC/SSD).
Old 03-05-2015, 07:27 PM   #3
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ya i tried that, fresh download and changed folder locations. i use to work just fine until the new windows install.. it still works on my little netbook but i cant play with tables on a 10in screen all day lol
IG-Joey_Soul
Old 03-08-2015, 11:32 AM   #4
Grip Ronin
The Mechanic
Grip Ronin's Avatar
be great if someone from openflash team would help with their software -_-
IG-Joey_Soul
Old 03-08-2015, 11:48 AM   #5
cnk
Drives: '13 DGM BRZ Limited
If you're running win8 there is a patch you have to install. It's on their site.
Sent from my SAMSUNG-SM-N900A using Tapatalk
cnk is offline   Reply With Quote
Old 03-08-2015, 01:51 PM   #6
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
There shouldn't be any problem with running OFM on a computer with a SSD. In fact I haven't found a hardware combination that it was unable to run on. As suggested earlier if you are running into issues, delete the existing Openflash folder that is on you C drive and do a fresh installation. Other than that I can't think of any other reason that you would b having a problem.
Old 03-08-2015, 02:35 PM   #7
Tromatic
I had a problem with mine that drove me INSANE. The OFT dudes had not seen it before, but did their best to help. I tried EVERYTHING, to include wiping and re-installing Window's 7 Pro. As far as I can tell, the problem was a bad download or install of C++. I have no idea why that would happen, but it has not happened since.
I'm back to using a heavily tweaked version of Windows, no problems.
I finally got smart and used Macrium Reflect to save a bone-stock install of Windows for troubleshooting.
It's a pain, but try a fresh install of Windows (turn updates off as well) and just the OFT. When done, disable your internet connection before connecting the tablet. Fingers crossed. It's probably something real simple that's nearly impossible to figure out!
ETA: Googled PWGPRO, several answers, so I have no idea what it is.
Tromatic is offline   Reply With Quote
Old 03-08-2015, 03:12 PM   #8
stugray
Drives: 2013 GBS BRZ Limited
It would also be great if you told us what OS you were using.
MS-DOS 6.0 wont cut it
Old 03-08-2015, 04:17 PM   #9
steve99
Try disabling antiviruis/firewall during install of openflash manager. Once loaded then re-activate antivirius/firewall software.
Old 03-08-2015, 04:31 PM   #10
cjd
cjd's Avatar
Drives: 2017 BRZ
FWIW, I've only run from SSD - both standard and built-in RAID (on-drive, and yeah - it failed...) and both Windows 7 and Windows 8.1
I have not tried Windows 10 yet
Sometimes odd mixes of things not fully installed can cause problems. Be sure you have the latest from the OpenFlash site (try viewing in private viewing mode/incognito to force it to ignore cached versions...) and as someone else mentioned, try uninstalling the MS libraries, reboot, then re-install.
C
Old 03-09-2015, 09:24 AM   #11
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Oh ya windows 7 ultimate 64bit , same os i was running on before i installed an ssd
IG-Joey_Soul
Old 03-09-2015, 09:58 AM   #12
stugray
Oh ya windows 7 ultimate, same os i was running on before i installed an ssd
In win7 if you right click on the icon, you can select "Run as Administrator" or "Troubleshoot compatibility".
Have you tried either one of those?
Or right click on icon, select properties, compatibility tab,and change compatibility mode and see if that changes the behavior.
Old 03-09-2015, 10:07 AM   #13
Grip Ronin
The Mechanic
Grip Ronin's Avatar
I have tried run as admin. I dont think i tried compatibility mode. Ill try that when i get home and post a pic of the error
IG-Joey_Soul
Old 03-09-2015, 12:32 PM   #14
Chimera
Drives: FRS
Be sure to BOTH install as admin, and run as admin. I have had before when I didn't do this the OFM would start processes that did not close properly, (became the windows equiv of zombies?), then I needed to reboot. When that happened it failed to modify a file under C:\OpenFlash that it needed access to. Rebooting and running as admin cleared it up.
OpenFlash Tablet will not connect to OpenFlash Manager rever5e Software Tuning 10 03-12-2022 10:17 AM
OpenFlash Manager 1.14 Problem Apoc Software Tuning 30 12-10-2014 12:14 PM
OpenFlash Manager 1.07.1 Mad_Hatter Software Tuning 24 04-24-2014 06:46 AM
Now Available: OpenFlash Manager 1.04 Shiv@Openflash Software Tuning 37 12-14-2013 10:02 PM
