Old 02-01-2019, 11:46 AM   #29
wally
SosMula
wally's Avatar
Drives: 2013 DD White pearl
Run E85 my exhaust has no residue and my oil doesnt go black (my e85 is true 85% ethanol all the time)
What are you putting to the wheel? I am thinking of going E85 on my GT86.
Rota Grid 18x9,5 ET+38 Valenti CBW GCS Shark Antenna Acrylic Headlight Covers
wally is offline   Reply With Quote
Old 02-01-2019, 10:15 PM   #30
steve99
Drives: FT86
Out dynos read diffrent to usa
Stock car here does about 110kw at wheels
Header and tune on petrol about 125 kw
Header tune and e85 about 135 kw
Our petrol is about USA 91, so if your on 93 petrol you will already be closer to the e85 power outputs
European 98 ron petrol is better than Australian 98 so you wont get as big a jump to e85 as in Australia
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Lantanafrs2 (02-01-2019), wally (02-02-2019)
Old 02-02-2019, 12:02 AM   #31
Youngmanhenry
Drives: Subaru BRZ
my exhaust has aids
Sent from my SM-G930T using Tapatalk
Youngmanhenry is offline   Reply With Quote
Old 02-02-2019, 12:12 AM   #32
Originally Posted by Youngmanhenry View Post
my exhaust has aids
Haha.. really? Dallas? Did you drive it into the ocean at some point?
Old 02-02-2019, 12:33 AM   #33
Youngmanhenry
Drives: Subaru BRZ
the car came from new york
Old 02-02-2019, 12:41 AM   #34
Aha! From the looks of the fasteners on that control arm, you rescued it in plenty of time.
Youngmanhenry (02-02-2019)
Old 02-02-2019, 01:15 AM   #35
Impureclient
Drives: 2015 FR-S
I had a ton of soot and it even was shooting behind the car onto the ground in the garage as I warmed it up. That was with aftermarket UEL header, over pipe and OFT.
I had a member in here, Tor, adjust the tune and it went away significantly on the tail pipe and no more on the ground at all.
Old 02-02-2019, 01:47 PM   #36
wally
SosMula
wally's Avatar
Ah I see, except from E85 being cheaper I wont notice a huge difference between E85 and 98 then.
Old 02-02-2019, 02:31 PM   #37
ermax
ermax's Avatar
It’s actually more like break even (at least in my area) cost wise due to the MPG drop with E85. For example I get about 250 miles on a tank of E85. I am completely stock with the exception of E85 and it’s a very noticeable increase in power. I don’t think he was saying it isn’t an improvement. It just isn’t as big of an improvement if you are going from high octane fuel to E85 vs lower octane fuel to E85. In my case I went from 93 to E85.
The Following User Says Thank You to ermax For This Useful Post:
wally (02-03-2019)
Old 02-03-2019, 05:56 AM   #38
wally
SosMula
wally's Avatar
Gotcha, thanks for explaining.
Removed Stock Exhaust... is this normal? ADFShark Engine, Exhaust, Transmission 23 02-04-2017 07:14 PM
UEL headers = black soot on exhaust tips? LaertesSon Issues | Warranty | Recalls / TSB 11 05-13-2016 08:46 AM
Soot in Exhaust...Normal? MasonL1997 Scion FR-S / Toyota 86 GT86 General Forum 55 12-02-2015 04:27 PM
Aftermarket exhausts causing black soot J_kennington Engine, Exhaust, Transmission 25 05-21-2014 09:40 PM
Water with black soot in exhaust KamalT Engine, Exhaust, Transmission 17 01-08-2013 09:28 AM
