Old 01-30-2019, 01:49 PM   #1
omadab
Drives: n/a
Black soot in exhaust. Normal?
Hello people,
I am currently in the market for a BRZ. I have been looking around and noticed some cars have black soot in the exhaust and that the oil smells like gasoline. To me, it seems that the car is running rich and that either there is a leaking fuel injector or the piston rings are worn. I just wanted to know if this is normal in boxer engines or if the piston rings are simply worn because the previous owner didn't take care of their car.
Any insight is appreciated
Thanks,
oma
omadab is offline   Reply With Quote
Old 01-30-2019, 01:56 PM   #2
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
is it stock, or does it have headers and a tune?
Breadman is offline   Reply With Quote
The Following User Says Thank You to Breadman For This Useful Post:
omadab (01-30-2019)
Old 01-30-2019, 01:59 PM   #3
StraightOuttaCanadaEh
Wes
It runs rich at startup while the cats are warming up. So I would say smell it after the warm up sequence is complete
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
omadab (01-30-2019)
Old 01-30-2019, 02:16 PM   #4
ermax
ermax's Avatar
Every car I've ever owned has required me to clean the tips weekly or else they would be black. Not wet, just dry black powder. I suspect it has a lot to do with my driving habits though. Since switching to E85 in my FRS I have gone about 9000 miles and the tips are crystal clear. I am intentionally not cleaning them to see how long they stay clean.
The Following User Says Thank You to ermax For This Useful Post:
omadab (01-30-2019)
Old 01-30-2019, 02:19 PM   #5
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Normal af.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 3 Users Say Thank You to 8RZ For This Useful Post:
Leonardo (01-30-2019), omadab (01-30-2019), Tcoat (01-30-2019)
Old 01-30-2019, 02:32 PM   #6
omadab
Drives: n/a
stock
Old 01-30-2019, 02:33 PM   #7
omadab
Drives: n/a
That I agree on, but its not just a little bit of powder like my other cars, I slide my finger inside and It is PURE black. There's a good amount of it
Old 01-30-2019, 02:35 PM   #8
omadab
Drives: n/a
Good point. Would it be because of the ethanol content in the fuel maybe? Would it be because of maybe the previous owner put low grade fuel inside the tank?
Old 01-30-2019, 02:41 PM   #9
humfrz
That's the way my stock 2013 FR-S is. Why? Because of a lot of cold starts and short trips.
humfrz
omadab (01-30-2019)
Old 01-30-2019, 02:44 PM   #10
ermax
ermax's Avatar
Ethanol burns cleaner so it doesn't leave deposits as much. The black you are talking about, is it wet or just dry powder? If it's wet I would assume it's oil and I would stay away, if it's dry I would say it's just from running a little rich. But probably just someone who doesn't bother cleaning the tips and drives the car in open loop a lot.
omadab (01-30-2019)
Old 01-30-2019, 02:55 PM   #11
omadab
Drives: n/a
humfrz
So would you say it is because of oil dilution? I don't even want to take the risk on this car anymore. I don't think there's anyway for me to check if its an injector, worn engine or having tons of short trips.
I think its important to mention that the car is also sitting in a show room at the dealership, so I doubt it goes through many short trips.
Old 01-30-2019, 02:56 PM   #12
omadab
Drives: n/a
its powder. What do you mean by "open loop a lot"
Old 01-30-2019, 03:03 PM   #13
Breadman
Breadman's Avatar
stock
as previously stated, its probably from when your cats are cold
omadab (01-30-2019)
Old 01-30-2019, 03:46 PM   #14
Lantanafrs2
Drives: 2013 frs red
Short hop driving soots them up. Or a bad tune.
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
omadab (01-31-2019)
Removed Stock Exhaust... is this normal? ADFShark Engine, Exhaust, Transmission 23 02-04-2017 07:14 PM
UEL headers = black soot on exhaust tips? LaertesSon Issues | Warranty | Recalls / TSB 11 05-13-2016 08:46 AM
Soot in Exhaust...Normal? MasonL1997 Scion FR-S / Toyota 86 GT86 General Forum 55 12-02-2015 04:27 PM
Aftermarket exhausts causing black soot J_kennington Engine, Exhaust, Transmission 25 05-21-2014 09:40 PM
Water with black soot in exhaust KamalT Engine, Exhaust, Transmission 17 01-08-2013 09:28 AM
