Old 01-05-2013, 11:35 AM   #1
KamalT
Drives: Pearl 86 GT
Water with black soot in exhaust
Just checked the rear of the car and the rear had black splash marks.
Checked the exhaust while it was running and it had clear water but some blackness in it.
The only mode is a flash ver 1.08. Only done 3158 km so far.
My old man said it was just CO2 burning off, and not worry.
Should I be worried or is he correct.
White GT | Visconti_TUNED
KamalT is offline   Reply With Quote
Old 01-05-2013, 11:37 AM   #2
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Normal. Water in exhaust means the catalyst system is working well. It then picks up the carbon in the exhaust as it exits and blows it on the car.
FRSFirestorm is offline   Reply With Quote
The Following User Says Thank You to FRSFirestorm For This Useful Post:
KamalT (01-05-2013)
Old 01-05-2013, 11:40 AM   #3
JDMenrique
DEEEERP
JDMenrique's Avatar
Yep, normal
JDMenrique is offline   Reply With Quote
The Following User Says Thank You to JDMenrique For This Useful Post:
KamalT (01-05-2013)
Old 01-05-2013, 11:45 AM   #4
KamalT
Drives: Pearl 86 GT
Thanks, load of my head
Old 01-05-2013, 11:51 AM   #5
dorifuto
If in doubt,flat out
dorifuto's Avatar
Drives: 2013 brz
One thing I've learned in life is to listen to the old dudes. They've been around and know more than you think.
dorifuto is offline   Reply With Quote
Old 01-05-2013, 12:02 PM   #6
cruzinbill
Drives: Argento 6spd FR-S
First car or somthing? You should def listen to the oldman if thats the case.
cruzinbill is offline   Reply With Quote
Old 01-05-2013, 12:23 PM   #7
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
All cars do this...Water (H2O) is a byproduct of the combustion of Hydrocarbons....along with CO (Carbon Monoxide) CO2 (Carbon Dioxide) C (Carbon) and NO2 (Nitrogen Dioxide) along with some other trace elements. I could go into the Stoichiometry of the whole thing...but that would require me to remember everything I learned in my Honors Chemistry class in High School...which for reasons (teacher was an asshole)...I'd rather not. @Visconti or one of the other tuners on the forum would most likely be able to explain it easier than me anyways. Basically water is produced in the combustion process which condenses as water vapor in the cooler exhaust sections of the car, that is the water vapor you see coming out of the exhaust. This is also the white vapor you see coming from car exhausts on cold days.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
The Following User Says Thank You to Sony For This Useful Post:
Tylub (01-08-2013)
Old 01-05-2013, 12:25 PM   #8
gmookher
thats great news
gmookher is offline   Reply With Quote
Old 01-05-2013, 12:31 PM   #9
Jeong
Drives: pet dragon
I saw a mustang basically spewing water out of its exhaust. Same thing? Didnt seem like something good. But then again still learning about cars
Jeong is offline   Reply With Quote
Old 01-05-2013, 12:32 PM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Look at the results of the chemical process
Certain amount of H2O is produced.
Old 01-05-2013, 12:40 PM   #11
Sony
Sony's Avatar
The more fuel that is used (Higher Horsepower), the more water is produced, I've seen cars with a small steady stream of water coming from the exhaust.
Also the addition of Alcohol, Meth or Water into the fuel system using E85, Methanol or Water Injection will also affect how much water is produced in the combustion cycle. The only time it would be a problem is if there is large amounts of white smoke coming from the exhaust that doesn't dissipate quickly and has a funny smell. This indicates a blown head gasket...
Jeong (01-05-2013)
Old 01-05-2013, 01:11 PM   #12
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
a byproduct of an explosion in your car is water vapor. Once said vapor hits a cool-er surface it condesces causing it to pool up, and until reved up a bit it will sit there. Therefore, it's completely normal and will be more noticeable in the winter when there are greater differences between the hot engine/exhaust and the ambient temperature. In short, don't even worry...dat shit's coo.
SkitterSkotter is offline   Reply With Quote
Old 01-05-2013, 07:34 PM   #13
KamalT
Drives: Pearl 86 GT
Aware of the water byproduct in exhaust but was more worried about the black in the water and covering the rear in black
Old 01-05-2013, 10:11 PM   #14
Sony
Sony's Avatar
Its just carbon the vapor picks up from the pipes...totally normal.
Clip of Black 86 TRD Exhaust and Some AutoX switchlanez FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 54 08-06-2013 12:59 PM
Water inside the car? YourFearlessLeader Issues | Warranty | Recalls / TSB 10 12-16-2012 04:55 PM
Black Friday @ CMS - Coilovers - Exhaust - Radiators - Suspension - Gauges + More! Circuit Motorsports Announcements, Contests, Giveaways 1 11-26-2012 05:43 PM
Black exhaust FoolCyclist Engine, Exhaust, Transmission 15 06-14-2012 10:37 AM
