Drives: Man
Soot in Exhaust...Normal?
Hi everyone,
Ive had the car for just over 3 months and am the second owner with the car currently having 31 thousand kilometers. Now, when ever i go WOT and get out of the car after driving, i look at the exhaust and notice a small amount of black soot in the exhaust. Is this normal? Then if i dont clean it, after a fair bit of spirited driving i find the exhaust having quite a lot of soot inside it. Is this normal? (Refer to pictures, one is still dirty, the other i have cleaned) Thanks, Mason |
Drives: 2015 FR-S
Unburnt fuel from running rich. Normal.
| The Following User Says Thank You to Impureclient For This Useful Post: | MisterSheep (11-23-2015) |
Drives: subaru
Seems normal (i hope). All the cars iv owned/scene have jt. Just make sure its not oil. I dont even bother cleaning mine
Drives: Man
Drives: Man
| The Following 4 Users Say Thank You to MasonL1997 For This Useful Post: |
No, the black "soot" you're talking about is just the carbon buildup due the afr being rich. All cars are set up to run a little rich in stock form - rich is "safe" from the manufacturer perspective. It will not cause injector problems every car has this buildup on the tips it's just some of them you can't see it. Also the FA20 uses Direct injection and port fuel injection. i.e. it has 8 injectors. Port injection still works much better for low rpm and idling for emissions & power. If anything were to be effected by soot it would only be the 4 injectors within the cylinders. At WOT at some points I'm pretty sure it uses both and you'll get that carbon on the tips the more frequently when that happens. Just keep cleaning it every month or so, so that it doesn't get caked on.
| The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post: | humfrz (11-23-2015), MasonL1997 (11-23-2015) |
#8 | |
Drives: Man
Drives: Scion FR-S 10 Series #2263
If you're curious to learn more about the port / direct injection modes...you've come to the right forum!
http://www.ft86club.com/forums/showthread.php?t=50827 http://www.ft86club.com/forums/showthread.php?t=3172 |
| The Following 3 Users Say Thank You to aegisdrgn For This Useful Post: |
#10 |
| The Following User Says Thank You to Hotrodheart For This Useful Post: | Ultramaroon (11-23-2015) |
#11 |
Drives: 17 Alfa Romeo 4C
Is that the same black soot on the floor?
#12 |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#13 |
Drives: 2014 BRZ Limited
You can monitor your AFR with Torque to see if you're running the right mixture. It usually runs about 14.5 to 1.
#14 |
Drives: 2015 CWP BRZ Limited
| TRD Exhaust/Intake Installed - Super loud - Problem or Normal?? | Chase86 | Engine, Exhaust, Transmission | 21 | 02-04-2019 01:02 AM |
| Undercarriage (exhaust piping) rust, normal? | gonzalj1 | BRZ First-Gen (2012+) — General Topics | 18 | 09-21-2015 01:22 AM |
| IS IT NORMAL | WGMGR | Scion FR-S / Toyota 86 GT86 General Forum | 40 | 12-08-2014 05:19 PM |
| Aftermarket exhausts causing black soot | J_kennington | Engine, Exhaust, Transmission | 25 | 05-21-2014 09:40 PM |
| Water with black soot in exhaust | KamalT | Engine, Exhaust, Transmission | 17 | 01-08-2013 09:28 AM |
