go_a_way1
Old 01-19-2019, 04:06 PM   #3977
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by JOSE_FBR7777 View Post
Ok so I was thinking of going staggered but I didn’t know what size to run, whit the sizes you gave me would I still be able to put coil overs?
Yes, of course.
I have coils now, but had 1" drop springs for 65,000 miles. IMO, 1" drop springs are great for DD.
I LIKE TIRES!
Old 01-19-2019, 04:08 PM   #3978
JOSE_FBR7777
Drives: Scion FR-S
Yes, of course.
You got a picture of what the set up would look like?
JOSE_FBR7777 is offline   Reply With Quote
Old 01-19-2019, 04:13 PM   #3979
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Are you asking about my car?
Cause, my car is the silver FR-S in this thread.
https://www.ft86club.com/forums/showthread.php?t=132471
I LIKE TIRES!
Old 01-19-2019, 06:39 PM   #3980
Mr_Eyo
Drives: 2017 Toyota 86
I used the new fitment simulator in the other stickied thread to find out that 255/35 on 18x8.5" +45 clears everything at stock height and -2 deg camber in front. Does anyone currently run this?
Mr_Eyo is offline   Reply With Quote
Old 01-19-2019, 07:03 PM   #3981
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Personally, I'd want a wider wheel for a 255. I think you will have rubbing issues with that much camber and a 255. It wont be flush at all either. I know it will work if you add a 15mm spacer. How are you getting -2 camber?
I LIKE TIRES!
Old 01-19-2019, 07:25 PM   #3982
JOSE_FBR7777
Drives: Scion FR-S
What’s up man, question am I able to run 255/35 in the rear and 225/40 235/40
Old 01-19-2019, 09:39 PM   #3983
Mr_Eyo
I have the CSG Spec Tein Flex A's.
Old 01-19-2019, 09:56 PM   #3984
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Ok....With coilovers, you won't have any issues with a 18x8.5 +45 with a 255/35/18.
What wheels are you looking at?
I LIKE TIRES!
Mr_Eyo (01-20-2019)
Old 01-20-2019, 12:28 AM   #3985
Mr_Eyo
Thanks. I already have the Enkei TFR in gunmetal gray running 225/40. They're a bit stretched. The 255s offer an extra inch of width to hopefully help put down supercharger power better.
Current w/ 225/40:
http://imgur.com/a/t2NenXC
Old 01-20-2019, 01:37 AM   #3986
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Current w/ 225/40:
Those Enkies look great on your car! What tire are you thinking of getting? One that's 200 tread wear?
I LIKE TIRES!
Old 01-20-2019, 04:26 AM   #3987
Mr_Eyo
Thanks. Actually, I like these all seasons. 400 TW and AA traction IIRC. BFG gforce comp 2.
The Following User Says Thank You to Mr_Eyo For This Useful Post:
Leonardo (01-20-2019)
Old 01-23-2019, 07:32 PM   #3988
JOSE_FBR7777
Drives: Scion FR-S
Yes, of course.
What up man can I run 245/40/r18
Old 01-23-2019, 07:37 PM   #3989
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes, it is 1.1 inches taller. (will raise your car 0.55 inch)
A 245/40/18 has an outside diameter of 25.7"
A 215 /45/17 has an outside diameter of 24.6"
A 245/35/18 has an outside diameter of 24.8"
I LIKE TIRES!
JOSE_FBR7777 (01-23-2019)
Old 01-25-2019, 02:32 AM   #3990
baiz1989
Drives: WRB BRZ
Looking to pick up the Enkei Raijins
I am on the stock suspension setup, will these fit 18 x 8.5 with 245/40 tyres on front and rear? Is it going to raise the car to much ?
Thanks in advance
baiz1989 is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
