Old 12-24-2018, 01:55 PM   #15
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
So is this really a complete kit for those NA or do you still need fittings? Or is the issue just with FI setups?
SuperTom is offline   Reply With Quote
Old 12-24-2018, 02:02 PM   #16
Vesartis
Vesartis's Avatar
Drives: 2016 Subaru BRZ Series.HyperBlue
It is a complete kit for NA, just with the varying port sizes, they picked a hose size in-between and you have to make sure to tighten the clamps well. Adapters could make it easier to tighten things.
The problem is some FI kits use the throttle body ports, or relocate stuff, so you might need new hoses or a new place to tap into the coolant if you aren't switching to an air-to-oil cooler.
Vesartis is offline   Reply With Quote
Old 12-24-2018, 02:43 PM   #17
justinco
justinco's Avatar
Drives: 2022 GR86
Originally Posted by Anthonyc77 View Post
Justinco do you have the data for the temp recordings? You say its not recommended for track usage but if the average temp delta is still lower then without one it might be worth it. Plus you should try and measure temps after a cool down lap as they might return to a usable temp faster with this oil cooler vs without one.
Yea, see below. Ambient temps for me were in the 90's and I drove a bit harder during the oil cooler test (higher coolant temps). Not a great data comparison but it was the best I could do. I saw hardly any change with the cooler when driving near the max. I'll do another test at some point with this.
justinco is offline   Reply With Quote
Old 01-14-2019, 09:25 PM   #18
dpaqu
Drives: 2018 Gt86
I have to wonder if the coolant temp difference would have shown a bigger oil temp difference without a cooler.
dpaqu is offline   Reply With Quote
Old 01-14-2019, 09:35 PM   #19
justinco
justinco's Avatar
Drives: 2022 GR86
Great point! That would make sense for sure.
VIDEO - Install guide for OEM style coolant loop Oil cooler. The Sentinel DIY (Do-It-Yourself) Guides 44 10-15-2018 08:42 AM
Kraftwerks Oil Cooler Sandwich Plate FS pgranberg11 Engine, Exhaust, Bolt-Ons 21 08-23-2018 09:33 AM
Oil sandwich plate w/ ports for oil cooler and sensors drz400dude Forced Induction 15 08-24-2017 11:38 AM
oil cooler sandwich Spacer MattHoffman Want-To-Buy Requests 1 10-20-2015 09:29 AM
OFT + Oil cooler sandwich plate Sterling Doc Engine, Exhaust, Bolt-Ons 5 07-12-2015 12:45 AM
