Old 01-07-2019, 01:21 PM   #57
gtengr
Drives: 2017 BRZ
Originally Posted by 86MLR View Post
What is the effect on bearings at high load and low RPM, lets say for example 3k rpm and 300nm, as apposed ti 6k rpm and 300nm.
Exponentially increased inertial forces at higher rpm in combination with a reduction in film strength due to the increased shear rate (bearing is spinning faster on the journal). The common rule of thumb with oil pressure is that the supply should be on the order of 10 psi per 1k rpm. What is the equivalent rule of thumb that relates high torque to oil pressure and low rpm?
gtengr is offline   Reply With Quote
Old 01-07-2019, 01:29 PM   #58
gtengr
Drives: 2017 BRZ
. In fact, Delicious Tuning has meantioned in threads that they tend to tune for less low end torque, even on the superchargers, in order to protect the rods. They offered the same to me or to go more aggressive, and I opted to be conservative for my SC. As mentioned before, the source of why low end torque is an issue is due to a higher likelihood of preignition and lower oil pressures. These are reliability concerns that transcend the track world into everyday driving situations.
I'm lost as to why you keep bringing the rods back into this bc i've not posted anything to the contrary to the above when it comes to rods. The motors that are breaking at low rpm high torque are generally breaking rods though, not spinning bearings.
Old 01-07-2019, 05:09 PM   #59
86MLR
86MLR's Avatar
As you stated, lower rpm = lower oil pressure.
The journal at the rods, due to low pressure and high load, can "push through" the oil layer at the bearing.
Therefore under high load there is a draging effect at the bearing.
This dragging effect can and does contribute to wear.
Dragging at the bearing can and does contribute to rod failure through excessive plastic deformation of the rods.
By excessive I mean more plastic deformation that the rod was engineered for.
The Following User Says Thank You to 86MLR For This Useful Post:
Irace86.2.0 (01-08-2019)
Old 01-08-2019, 04:59 PM   #60
gtengr
Drives: 2017 BRZ
But you're saying it's the excessive torque. So again, what is the numerical rule of thumb that factors in the torque?
Rods are not designed to sustain any plastic deformation in service. Plastic deformation on a rod means it's buckled or the big end has gone out of round. The rods are not engineered to last under either condition in the context of high performance street engines.
Also, the overlay surface of rod bearings are made of a softer material than the rods, and would be toast before the rod if the oil film is compromised to the point that the bearing iould cause localized plastic deformation on the rod.
I understand what you're saying about skimming the bearings. I do. I still disagree citing the qualifiers I listed earlier about extreme torque/lugging the engine. There are a few people on here who have broken rods and had serviceable bearings. I maintain that in general, unless one is treating their engine like an idiot (e.g. lemme try to hitting max boost in 6th gear at 2000rpm), then the idea that low rpm torque is as significant as high rpm inertial loading when it comes to oil pressure is bunk.
Old 01-08-2019, 08:17 PM   #61
Grady
Grady's Avatar
I thought the rods were made of steel? No wonder they bend so easy!
The Following User Says Thank You to Grady For This Useful Post:
bfrank1972 (01-08-2019)
Old 01-08-2019, 09:08 PM   #62
86MLR
86MLR's Avatar
Material testing is cool.
Turbo Reliability VS Supercharger reliability KGB Forced Induction 130 09-08-2015 09:55 AM
Turbo options/ reliability of Brz danoo Forced Induction 13 06-15-2015 09:26 PM
FI Reliability pheonixone Forced Induction 42 02-22-2015 12:51 PM
