#43 |
| The Following 4 Users Say Thank You to Grady For This Useful Post: |
#44 | |
Drives: Q5 + BRZ + M796
#45 | |
Drives: 2017 BRZ
From one of my posts in another thread on how low RPM torque stresses rods: As the combustion gas expansion drives the piston down the cylinder, the cylinder volume is also increasing via piston travel. As the rpms are decreased, the gas expansion rate may stay about the same, but the slower cylinder volume expansion rate results in a harder push against the piston over less degrees of crank rotation. An analogy is if you were hitting a punching bag that's rocking back and forth, it would be less stressful on your arm to punch it while it's moving away from you. The slower it's moving away from you, the more you'll feel that punch in your arm. That's what's happening with the rods at high torque and low RPM. That cylinder pressure is trying to expand, but the piston isn't getting out of the way as fast as it does at high RPM, and the result is more force in the rod. |
| The Following 2 Users Say Thank You to gtengr For This Useful Post: | Irace86.2.0 (01-03-2019), StraightOuttaCanadaEh (01-03-2019) |
#46 |
Probably not before. More like while, as in while the rebuild is happening.
That’s the pump for reference. Not saying this is needed or will fix the oil starvation issue. Just saying this and the larger capcity pump exist. https://www.counterspacegarage.com/reimax-oil-pump-fa20
#47 |
Drives: Toyota GTS 86
Oil pressure at low RPM is fine. It's at higher RPM that it has insufficient pressure. I'm moving to a 50 weight, and if that doesn't fix it, then I'll try a 60 weight.
2013 Toyota 86: 275rwkW
Coyoda Water-to-air Intercooled Turbo with GTX2863. CP Carillo Rods and Pistons. Motec M150 ECU. Motec C125 Dash. Holinger SG 6 Speed Sequential Gearbox. OS Giken LSD. MCA Reds Coilover. AP Racing Essex Sprint Front Brakes. PWR Radiator and Intercooler heat exchanger. |
#48 |
Drives: 2013 Asphalt FRS
How and what you upgrade your motor with will depend on how you drive it....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
| The Following User Says Thank You to FRS Justin For This Useful Post: | Irace86.2.0 (01-05-2019) |
#49 | |
I hit peak boost at redline where a turbo with a wastegate can hit peak boost or the same boost at half of those rpms. Hitting the same peak torque at half the rpms where oil pressure is half as well is an issue. This, along with other properties of having relatively higher torque at lower rpms, is why turbos pose more risk than superchargers that have the same peak torque.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | DarkPira7e (01-05-2019) |
#50 | |
Rust bucket enthusiast
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Irace86.2.0 (01-05-2019) |
#51 | |
Drives: 2017 BRZ
#52 | |
This is why alot of turbo cars lunch themselves, well, the driver is responsible for the lunch date. Flooring the pedal at 2k rpm is a sure way to put a bay window in your block. Smarter than me guy talking turbo >
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
| The Following User Says Thank You to 86MLR For This Useful Post: | Irace86.2.0 (01-05-2019) |
#53 | |
If oil pressure is a problem at high rpms then it usually is because of an oil temp issue or an oil starvation issue like lacking baffling in the oil pan while taking a long, high-g turn.
#54 | ||
Drives: 2017 BRZ
#55 | |
#56 | |
The topic was talking about the reliability differences between a supercharger and a turbocharger. It seems to be common knowledge that even if a turbo and SC system share peak hp and torque, the fact that the turbo will hit peak torque earlier in the rpms was one reason why there is a known greater risk of going the turbo route. In fact, Delicious Tuning has meantioned in threads that they tend to tune for less low end torque, even on the superchargers, in order to protect the rods. They offered the same to me or to go more aggressive, and I opted to be conservative for my SC. As mentioned before, the source of why low end torque is an issue is due to a higher likelihood of preignition and lower oil pressures. These are reliability concerns that transcend the track world into everyday driving situations.
| Turbo Reliability VS Supercharger reliability | KGB | Forced Induction | 130 | 09-08-2015 09:55 AM |
| Turbo options/ reliability of Brz | danoo | Forced Induction | 13 | 06-15-2015 09:26 PM |
| FI Reliability | pheonixone | Forced Induction | 42 | 02-22-2015 12:51 PM |
