Old 12-30-2018, 01:00 AM   #15
Face_Plant
Face_Plant's Avatar
Drives: 2015 Scion FR-S
Originally Posted by DearDiaryJackpot View Post
https://www.iagperformance.com/IAG-S...g-eng-1209.htm
This is the motor I’m talking about. They have 6 options. And if you want it bulletproof, do a closed deck and DO what ever they tell you to do, if you listen to anybody else, you will loose the engine. I haven’t look at the manifold rubbing issue.
Off topic fun fact: IAG is ~25 minutes from my house.
Face_Plant is offline   Reply With Quote
Old 12-31-2018, 12:04 AM   #16
DearDiaryJackpot
DearDiaryJackpot's Avatar
Drives: FRS
Best Turbo kit for stock engine? As of 2018...
Off topic fun fact: I hate you
I’ll be living in NJ soon. So about 2.5hrs from my new place. Hopefully!
DearDiaryJackpot is offline   Reply With Quote
The Following User Says Thank You to DearDiaryJackpot For This Useful Post:
Face_Plant (12-31-2018)
Old 12-31-2018, 12:35 AM   #17
FRS Justin
Drives: 2013 Asphalt FRS
Bullet proof a FA20 means staying under 500whp and that's still pushing it for the term bullet proof. Yes they can push 700 to 800 whp but not for long...
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-31-2018, 12:40 AM   #18
Face_Plant
Face_Plant's Avatar
Even if you lived down the block from IAG, I've heard that going there isn't worth it unless you have VERY deep pockets and don't mind being on their waiting list for about 3 months just to have your car looked at for an estimate.
Old 12-31-2018, 05:17 AM   #19
jflogerzi
jflogerzi's Avatar
Boost + FA20 Motor not equal safe anywhere. But to be safest on stock internals low boost around 7-8 PSI with e85 and most any decent kit will work. 2 things that will be the same no matter which kit is proper install and a solid tune.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Conman (12-31-2018)
Old 01-01-2019, 09:15 PM   #20
DearDiaryJackpot
Drives: FRS
I wouldn’t have them look at the car. It would cost a fortune. But buying 1 of their motors and not pushing 40 psi, it should last. There was a guy in Nasioc with their stage 2 motor at 500whp for 80k+ miles, no problem, even redlining the car weekly.
OP doesn’t sound like he needs power, he just wants to have fun. I say do it once and do it right. Motor, turbo, 9 psi. It should last for years.
Old 01-02-2019, 02:21 AM   #21
johl
johl's Avatar
Drives: toyota 86
Why build the motor to only then run 9 psi? The standard motor will handle that just fine for some time. Even if/when the motor does decide it has had enough you could probably buy 2-3 replacement motors for less money than a built engine.
Don’t get me wrong, I personally like to do it right and do things once. But i don’t see the value in building a motor to run such i minor bump in power, especially when you see lots of guys running ~300hp on unopened motors
johl is offline   Reply With Quote
Old 01-02-2019, 10:17 AM   #22
toast
Drives: 14 BSP Edelbrock BRZ
When the stock block grenades nothing says that it will do so peacefully. Yes, you can buy a used shortblock for $2k but if your heads are damaged when it goes you are looking at a much larger bill than just starting off with a built shortblock. Each head costs as much as the shortblock. As soon as my Edelbrock is paid for money is going in a fund to get the IAG block so that I can run ACE headers and E85 with the supercharger and never worry about the motor again.
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
johl (01-02-2019)
2018 Lexus LS has a livelier look and new twin-turbo V6 vh_supra26 Other Vehicles & General Automotive Discussions 17 10-06-2020 10:19 PM
Brand New 2018 BRZ - Check Engine Light at 85 Miles Clutch Issues | Warranty | Recalls / TSB 40 02-25-2019 03:40 PM
AVO Turbo Kit issues in 2018 brianzlive Forced Induction 8 04-08-2018 11:37 PM
This Is The 2018 Ford Fiesta ST, And It Has A 200 PS 1.5L Turbo vh_supra26 Other Vehicles & General Automotive Discussions 30 08-01-2017 09:39 AM
Ptuning turbo 458whp update Stock engine anajri Forced Induction 32 02-11-2015 12:37 PM
