Old 12-25-2018, 02:28 PM   #1
Conman
Conman's Avatar
Drives: Red FRS
Best Turbo kit for stock engine? As of 2018...
What’s the safest turbo kit to run on stock engine? I want to run E85 flex fuel. Wondering what to budget for parts + install. Thanks.
Conman is offline   Reply With Quote
Old 12-25-2018, 04:03 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
A supercharger
The Following User Says Thank You to Kiske For This Useful Post:
Conman (12-25-2018)
Old 12-25-2018, 04:17 PM   #3
Grady
Grady's Avatar
Any kit is “safe” if tuned correct. However if you can not afford a blown engine you may not want to. A blown engine is possible with any kit.
The Following 3 Users Say Thank You to Grady For This Useful Post:
Conman (12-25-2018), gtengr (12-26-2018), mrg666 (12-30-2018)
Old 12-25-2018, 04:32 PM   #4
Conman
Conman's Avatar
Drives: Red FRS
I Don’t like the superchargers. I will build the engine if and when it happens... The MAP kit looks pretty nice. They also offer just the hot parts kit. Is there a better set up for the stock engine I could piece together?
Old 12-25-2018, 05:03 PM   #5
J1Avs
Drives: 2018 BRZ tS
PTuning’s Kit. You’ll probably spend the most on it with all the accessories, but definitely the most comprehensive.
J1Avs is offline   Reply With Quote
The Following User Says Thank You to J1Avs For This Useful Post:
Conman (12-25-2018)
Old 12-25-2018, 05:31 PM   #6
Conman
Conman's Avatar
Drives: Red FRS
That kit looks great and I know the Vband is big plus. Would the larger 3076 turbo be better or worse for a daily driver than the precision 4831?
Old 12-25-2018, 10:00 PM   #7
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
There is zero reason for anything that big on the stock if your going for safety, all your doing is getting lag for no reward on low boost. 2867 is already more than capable at 400whp.
The Following 2 Users Say Thank You to Kiske For This Useful Post:
ATL BRZ (12-26-2018), gtengr (12-26-2018)
Old 12-25-2018, 10:13 PM   #8
DearDiaryJackpot
DearDiaryJackpot's Avatar
Drives: FRS
I would go with map because of the ewg. I know ptuning has it as an option but with the $2.5k in difference , you can buy an AIG motor and be worry free.
DearDiaryJackpot is offline   Reply With Quote
Old 12-25-2018, 10:51 PM   #9
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
There is no singular best kit. I'd recommend searching & doing some more research to determine what your requirements are and work backwards from there.
Does best mean most efficient heat management? Spool time? Cost?
mistople is offline   Reply With Quote
The Following User Says Thank You to mistople For This Useful Post:
Joveen (12-26-2018)
Old 12-26-2018, 02:38 PM   #10
toast
Drives: 14 BSP Edelbrock BRZ
You have given zero parameters for what is best. Your first sentence included 'safest'. Your second said E-85. Any turbo kit run 8 psi on E-85 will generate enough power to run a serious risk of bending the connecting rods. Then you said you will build the motor if it blows, so you don't really care about safe.
If you really want the 'safest' (and have to have a turbo)I would recommend an AVO stage 1 kit NOT running E-85. While you enjoy that you can build a new short block with pistons and rods and get the bigger injectors you will need for E-85 and then look at stage 3. If you need more than the 400 hp that gets you can pull that kit off and sell it and then go nuts.
If you go big right away (which I have to assume is a terrible car for a daily driver with lag and all) and snap a con rod shards of metal can go through the oil system and destroy your valvetrain. A short block is cheap. A long block is very much not. I did this on my STI; learn from my stupidity.
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
Old 12-26-2018, 04:33 PM   #11
Grady
Grady's Avatar
I would have to 2nd on the AVO kit for a daily. I am running e85 at 8 psi. I do like how soon the turbo kicks in. Getting 6psi at 3400, 8 at 3800. We ran a 10 psi map and I beleive it got there at 4000 rpm. However with the smaller/stock exhaust it will taper back down between 7 and 8 at redline.
The Following User Says Thank You to Grady For This Useful Post:
Conman (12-26-2018)
Old 12-26-2018, 05:11 PM   #12
Safest? GReddy. Runs the lowest boost. Still 300+whp on ethanol at just 7 psi.
chaoskaze (12-28-2018), Conman (12-26-2018)
Old 12-28-2018, 06:30 PM   #13
Conman
Conman's Avatar
Drives: Red FRS
Is this what your talking about? Seems like the thing to do. So that would be like $3000 for the built engine +the labor to swap it withyour stock engine. Thinking I will probably save up the extra money to do the built block. You guys scared me away with all the" you will blow your block" talk. Are people were having issues with the manifold rubbing on the oil pan on the MAP kit?
https://www.maperformance.com/produc...kaAlPhEALw_wcB
Old 12-29-2018, 08:17 AM   #14
DearDiaryJackpot
Drives: FRS
https://www.iagperformance.com/IAG-S...g-eng-1209.htm
This is the motor I’m talking about. They have 6 options. And if you want it bulletproof, do a closed deck and DO what ever they tell you to do, if you listen to anybody else, you will loose the engine. I haven’t look at the manifold rubbing issue.
The Following User Says Thank You to DearDiaryJackpot For This Useful Post:
Conman (12-29-2018)
2018 Lexus LS has a livelier look and new twin-turbo V6 vh_supra26 Other Vehicles & General Automotive Discussions 17 10-06-2020 09:19 PM
Brand New 2018 BRZ - Check Engine Light at 85 Miles Clutch Issues | Warranty | Recalls / TSB 40 02-25-2019 02:40 PM
AVO Turbo Kit issues in 2018 brianzlive Forced Induction 8 04-08-2018 10:37 PM
This Is The 2018 Ford Fiesta ST, And It Has A 200 PS 1.5L Turbo vh_supra26 Other Vehicles & General Automotive Discussions 30 08-01-2017 08:39 AM
Ptuning turbo 458whp update Stock engine anajri Forced Induction 32 02-11-2015 11:37 AM
