Old 02-24-2017, 06:33 PM   #1
vh_supra26
Site Moderator
Drives: Supra
This Is The 2018 Ford Fiesta ST, And It Has A 200 PS 1.5L Turbo
This Is The 2018 Ford Fiesta ST, And It Has A 200 PS 1.5L Turbo With Cylinder Deactivation
With just a little over a week to go until the 2017 Geneva Motor Show, Ford have officially unveiled the new generation Fiesta ST.
Building upon the regular versions, the hot hatch uses a newly-developed 1.5-liter three-cylinder EcoBoost petrol engine that pushes out 200 PS (197 HP) and 290 Nm (214 lb-ft) of torque, allowing it to go from 0 to 100 km/h (62 mph) in 6.7 seconds, or 0.2sec faster than before.
Users can shift between three different driving modes: Normal, Sport and Track, which enable engine, steering and stability controls to be configured from motorway to track day condition.
Additionally, the new Fiesta ST also features what Ford claims to be an industry-first cylinder deactivation system for a 3-banger, which reduces fuel consumption in conditions where full capacity is not needed, and drops the CO2 emissions to an anticipated 114 g/km. This technology can disengage or re-engage one cylinder in 14 milliseconds, or 20 times faster than the blink of an eye.
Using a Ford Performance-tuned chassis, the brand's answer to the Renault Clio RS, Opel/Vauxhall Corsa OPC/VXR and Volkswagen Polo GTI problems has a 3-mode ESC, which allows drivers to select between full system intervention, wide-slip mode with limited intervention, and full system deactivation.
Available in both 3- and 5-door body styles, the 2018 Ford Fiesta ST comes with a distinctive exterior styling that helps it stand out over the regular models, and has a unique mesh grille, special bumpers on both ends, a roof-mounted spoiler and 18-inch alloy wheels, with a different pattern.
Inside, the new B-segment hot hatch is offered with Recaro seats and a flat-bottomed steering wheel, but buyers will get to select between more personalization items than before, including a range of trim elements for the steering wheel, gear lever, door pulls, and decorative dashboard spear.
Taking center stage in the middle of the dashboard is the SYNC 3 infotainment system, which uses a floating-style up to 8-inch in size display, and comes with punch and swipe gestures, voice commands, navigation system and smartphone connectivity through Android Auto and Apple CarPlay. The car can also be had with a premium B&O Play Sound System.
Ford says that the new generation Fiesta ST will become available for launch in early 2018. Prices will likely be announced close to that date.
http://www.carscoops.com/2017/02/thi...nd-it-has.html
vh_supra26 is offline   Reply With Quote
Old 02-25-2017, 10:32 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I really like the way the new FiST looks, but I don't understand why they dropped a cylinder?
MS, CSCS, TSAC-F, CPT
Old 02-26-2017, 04:04 AM   #3
serialk11r
Drives: '06 AM V8V Coupe
Save money right? Basically every Ford has a turbo now, so that's a sunk cost, but they can still chop cylinders off to cut costs.
Old 02-26-2017, 07:27 AM   #4
FR-S.13
Drives: 2021 Supra 3.0 premium
Ford doesn't currently offer anything I'm interested in, but I have to give them credit for giving actual car enthusiasts some options at an attainable price. And then they have the GT at the other end, so they've got most incomes covered.
FR-S.13 is offline   Reply With Quote
Old 02-26-2017, 08:07 AM   #5
bfrank1972
Drives: 2013 FR-S Argento
Yup that plus fuel economy & emissions will probably be a little better (even if an I4 also had cylinder deactivation). The thing will probably get insane fuel economy.
bfrank1972 is offline   Reply With Quote
Old 02-26-2017, 08:39 AM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
fuel economy, weight, space. I wonder how it sounds in 2 banger mode?
Old 02-26-2017, 09:26 AM   #7
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
I would assume brand standardization. I am not as up-to-date with Fords, but I think this was the engine in UK/Europe/Other markets. If that is the case, that is why you would be seeing it here now.
I think in other markets, engine displacement has to do with insurance. Therefore, if you can get the same/better performance from the same engine globally... why not.
dowroa is offline   Reply With Quote
Old 02-26-2017, 01:29 PM   #8
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I'm glad they finally cleaned up the center stack on the dash.
That headlight switch looks kinda odd.
krayzie is offline   Reply With Quote
Old 02-27-2017, 08:42 AM   #9
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Its the same headlight knob they've been using for years. What's odd about it?
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 02-27-2017, 08:47 AM   #10
krayzie
Drive From Home
krayzie's Avatar
I've never had a Ford. I'm just too used to a stove top knob instead of a dial.
Old 02-27-2017, 12:18 PM   #11
DAEMANO
Time Traveller
"allowing it to go from 0 to 100 km/h (62 mph) in 6.7 seconds "
I know 0-60 doesn't mean THAT much, but I'd expect a 0-60 time right about 5.9 - 6.2 for a car with...
"200 PS (197 HP) and 290 Nm (214 lb-ft) of torque"
...did it gain a bunch of weight, or just end up with sub optimal gears (for off-the-line performance?)
Old 02-28-2017, 08:52 AM   #12
WolfpackS2k
I've never owned a Ford either, but it seems pretty normal to me. Also preferable to a steering column stalk headlight switch.
Old 02-28-2017, 09:57 AM   #13
krayzie
Drive From Home
krayzie's Avatar
Because in terms of ergonomics if the selector has an infinite range (e.g. HVAC temp adjustment) then a dial would make sense, whereas for a few defined click selections a stove top knob like your Porsche headlight switch would be much easier to use.
Also cruise control stalk over buttons. Just me tho.
Old 02-28-2017, 10:23 AM   #14
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
The shift knob looks like Iron Man's helmet...
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Shamed by a Ford Fiesta ST spoolinast Off-Topic Lounge [WARNING: NO POLITICS] 39 05-03-2016 08:14 PM
My 225 whp 1990 ford fiesta aka the ford party Frog Other Vehicles & General Automotive Discussions 25 12-23-2015 01:13 PM
GT 86 vs Ford Fiesta ST a2cpc BRZ First-Gen (2012+) — General Topics 4 06-26-2013 12:35 PM
FRS/BRZ vs Ford Fiesta ST overlookedx FR-S / BRZ vs.... 32 02-28-2013 02:17 AM
2013 Ford Fiesta ST! SVTSHC Other Vehicles & General Automotive Discussions 26 11-28-2012 09:02 AM
