Old 11-21-2014, 08:35 AM   #1
anajri
Drives: GT86
Ptuning turbo 458whp update Stock engine
Hey guys
Finally was able to finally tune the car here is a list of upgrades
Fuel: pump 100 octane W/ AEM water/meth injection
ECU: Mortec M150 GT86 kit
turbo: ptunning kit with 3" down pipe but (perrin Back mufflers)
susp.: TRD
F/Pump: Stock
RPM: 8000 redline
the water/meth system comes online at 8lbs.
At the end, I could tell the recirculating waste gate and the Perrin 2.5Inch muffler at the End was restricting a bit so I believe it has a few more ponies left in her. the Dyno was reading a peak of 22 and going down to 20lbs but on the Aem tru boost the dial was reading a peak of 20 and coming down to 18 lbs. so I do not know take your pick...jejje
For some reason, I could not hook up the RPM signal, I could not find an easy Source so if anybody knows how to do it please show me because really what to see the Spool with rpm and the TQ #
All runs where done in 4th gear... but I also felt the Tires R888 (worn) fighting for traction so dont know if that had any downsides. anyway really happy with the outcome.....
Anyway feel free to ask away if you have any questios.
tried loading a little video but its not working I will keep trying
ok loaded it to youtube.
PS.. do not look at the AFR it was out of wack so we had to use the internal Wideband from motec
Alf
anajri is offline   Reply With Quote
The Following 8 Users Say Thank You to anajri For This Useful Post:
Cal3000 (11-21-2014), Calum (11-21-2014), JonAvalon (11-21-2014), lucid215 (11-21-2014), Mrc@ptuning (02-10-2015), rb6freak (11-21-2014), sw20kosh (11-21-2014), Whatabouteggs (11-22-2014)
Old 11-21-2014, 08:42 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Load video to youtube then post the link here.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Cessblood (11-21-2014)
Old 11-21-2014, 08:44 AM   #3
anajri
Drives: GT86
good call ill try that
The Following User Says Thank You to anajri For This Useful Post:
Sportsguy83 (11-21-2014)
Old 11-21-2014, 10:12 AM   #4
bfrank1972
Drives: 2013 FR-S Argento
Wow, stock motor, 458 rwhp, 8000 rpm redline, awesome. Really curious to see how the motor holds up.
bfrank1972 is offline   Reply With Quote
Old 11-21-2014, 10:47 AM   #5
anajri
Drives: GT86
jejejej me too......
Old 11-21-2014, 11:17 AM   #6
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Start reading here for the RPM signal http://www.ft86club.com/forums/showt...t=28800&page=4
rb6freak is offline   Reply With Quote
Old 11-21-2014, 12:56 PM   #7
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
what was the reason for Motec? no ecutek tuners where you are im assuming?
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 11-21-2014, 12:56 PM   #8
350matt
Drives: toyota mr2/ Toyota GT86
well its going to go bang isn't it?
just a question of when
350matt is offline   Reply With Quote
Old 11-21-2014, 01:19 PM   #9
bfrank1972
Quite possibly, but I'm interested in what goes bang first Motor might actually hold up for a while if tuned right, Ptuning makes a nice kit and know what they're doing. If it spends a lot of time at the strip it might be something in the driveline that goes...
Old 11-21-2014, 01:42 PM   #10
anajri
Drives: GT86
it was an impulse buy plus first started with fa20 club and got tired of having to log send log send log send
had someone give me a good deal on one...
Alf
Old 11-21-2014, 04:15 PM   #11
spitfire481
Drives: 2JZ FRS
Alf
It's a nice setup for sure. We installed one over the summer in a customer car
MoTeC
Build Thread
@spitfire481
Old 11-21-2014, 04:18 PM   #12
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Just a heads up, buddy of mine ran 470whp for almost a year, red-lined daily, never skipped a beat. He just got the motor built for more fun times. It's all about the tune.
slicktop is offline   Reply With Quote
The Following User Says Thank You to slicktop For This Useful Post:
hmong337 (11-22-2014)
Old 11-21-2014, 10:37 PM   #13
dabocx
dabocx's Avatar
Drives: Scion FRS
This is with the GTX3076 .63 ar?
dabocx is offline   Reply With Quote
Old 11-22-2014, 08:56 AM   #14
anajri
Drives: GT86
yES REAL NICE THE ONLY ISSUE Iam having is with the Ac it turns of at a Trafic light when the car stops but once im moving again seems to con on line again
any thoughts on this? I have tried everything
PTUNING Turbo Kit Owners Topic kanundrum Forced Induction 1238 12-11-2021 09:22 PM
PTUNING: 501WHP 377WTQ 20psi Stock Motor PTUNING Spec-SS GTX3076R Turbo System ptuning Forced Induction 47 06-16-2014 03:52 PM
Revworks turbo 10k update jamesm Forced Induction 88 02-13-2014 11:54 AM
PTUNING FR-S/BRZ Turbo Testing @ VMP 4/21/2013 Events@Ptuning Tracking / Autocross / HPDE / Drifting 12 01-13-2014 10:22 AM
Ptuning turbo kirlt bjun Forced Induction 9 11-16-2013 02:14 PM
