Old 12-25-2018, 02:22 AM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Can you feel 5-7 pounds of wheel weight per corner? 20 lbs total
How does 5-7 pounds per corner less of wheel and tire weight savings really feel like? I mean i am sensitive to an empty gas tank. So would i feel it especially over potholes and bumpy roads?
leevanf is offline   Reply With Quote
Old 12-25-2018, 04:56 AM   #2
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
It is a different perspective.
I felt much different when I changed to Enkei rpf1, but not much different taking out all the stuff from the trunk. (my trunk was stripped.)
FR-Sky is offline   Reply With Quote
Old 12-25-2018, 06:01 AM   #3
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
You should go test drive a fellow 86 owner's car with lighter wheel/tires.
Old 12-25-2018, 06:04 AM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
It's not the overall weight that it affects it's the unsprung weight. You feel it in the brakes, steering and suspension for the most part
TommyW is offline   Reply With Quote
Old 12-26-2018, 12:50 AM   #5
Maxxturbo
Also under acceleration.......
Maxxturbo is offline   Reply With Quote
Old 12-26-2018, 01:03 AM   #6
Impureclient
Drives: 2015 FR-S
I felt a 4.5 lb drop for sure changing wheels but got used to it pretty quick after a couple times driving it.
Old 12-26-2018, 01:12 AM   #7
Decep
Drives: 2013 FR-S Series 10
TBH i felt nothing going from stock wheels to 17x8 RPF1s which are super light. i didnt upsize tires either.
Old 12-26-2018, 01:13 AM   #8
jflogerzi
jflogerzi's Avatar
That's quite a bit. What wheel and tire combo did u get? You will notice.. but more on canyon and track days vs DD.
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 12-26-2018, 01:44 AM   #9
StraightOuttaCanadaEh
Wes
I notice a difference in acceleration and ride quality changing from summer to winter tires on the same rim
Instagram: @gt86ws
Old 12-26-2018, 02:20 AM   #10
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Outer wheel weight (tire) is more significant of a weight issue then alloy wheels. However, trying to reduce tire weight by 1-3 pounds can /is difficult.
Doing both at the same time (new alloys shaving 3-7 lbs per corner) and new tires.... 215 /40- 17" , you'd probably notice a difference. Or , if you'd be willing to go 16" wheel, you for sure can reduce down wheel weight that way fast, but tire weight could still be similar to a 17" wheel ( due to the fact most 16" tires tend to have a higher profile , like a 205- 55- 16" )
If you live where it rains a lot, don't skimp... get a quality rain tire (not all season)
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 12-26-2018, 03:53 AM   #11
leevanf
leevanf's Avatar
Hey adam, problem is this. I want the tws t66f in 16x7. That alone is a 10 lb savings. Problem is, tires are on the heavier side, likely 22-23lbs. Thats 2-3 more than stock primacy. So i net out about 7 lbs.
Old 12-26-2018, 03:55 AM   #12
leevanf
leevanf's Avatar
Looking at the TWS T66F 16x7, on 225/50 or 205/55 tires. Wheel is already 10lb savings vs stock. But tired are nearly 3 lbs heavier so its about 7 lbs net
Old 12-26-2018, 07:47 AM   #13
new2subaru
Weight Weenie
Drives: 15 FR-S
You can go 205/50 R16. From what I read this is a very capable tire and you'll lose a pound or two.
https://www.tirerack.com/tires/tires...omCompare1=yes
Old 12-26-2018, 10:20 AM   #14
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
That's the issue I can up with when looking at the t66f plus the offset is high so they will be really tucked in as well meaning you might have to add spacers for either brake kit or just for looks.
Went with lightweight Konig Hypergrams 17x8 at 16.5lbs and stock size tires in Hankook Evo's at 19 lbs . So saved about 6lbs total for a lot less money then the t66f setup
As for your question its similar to the lightweight pulleys where you can feel some acceleration gains in 1st and second. Suspension wise the wheels will be able respond to bumps better and easier on the brakes to stop a lighter wheel
SuperTom is offline   Reply With Quote
Which budget tire would you pick? Bonburner Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 54 09-25-2018 12:34 AM
cai with throttle body combos SmaxxSmith Engine, Exhaust, Transmission 9 02-17-2018 07:55 PM
Socal FS Namless Exhaust & Wheel Spacers Local Pick Up xbwhahax Engine, Exhaust, Bolt-Ons 2 12-27-2015 04:52 PM
If our cars pick up 8 wheel hp how much is that at the crank? pr086 Scion FR-S / Toyota 86 GT86 General Forum 10 01-18-2013 06:56 PM
Thoughts on wheel/tire combos TemeCal Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 08-27-2012 01:22 AM
