Old 12-23-2018, 11:27 PM   #15
It is much worse than any sort of driving due to the peak forces involved. A hammer blow dissipates high energy over a very short period of time. That is not remotely similar to even the force of a pothole strike transmitted through a tire.
Old 12-24-2018, 12:08 AM   #16
ZionsWrath
Thanks
ZionsWrath's Avatar
Rip my bearings then, i won't tell them if you don't
Old 12-24-2018, 12:41 AM   #17
The net effect may be as little as cutting a few thousand miles off of their overall life but it's real.
For the same reason that the vehicle weight must not rest on the wheels with the axle nut loosened, it's MUCH worse to hammer on that assembly with a loose axle nut than with it cinched up so the balls are properly loaded up in the races.
Here's a pretty good picture of what happens internally. The wheel bearings are a flavor of duplex angular contact type.
The axle nut is loose on the left.
http://www.bardenbearings.co.uk/index.cfm_articleid_717
Old 12-24-2018, 04:15 PM   #18
dstrout
dstrout's Avatar
So, new knuckles and bearings it is. Took the knuckle completely off, soaked it with PB Blaster, and took a 2 1/2 lb hand sledge to it from the back side. No movement.
The next question is, is it possible to disconnect the ebrake cable from the knuckle / bearing assembly? I don’t mind buying a new assembly but the ones I see on eBay have the ebrake cable with them which doesn’t bode well. Am I going to end up having to remove and replace the ebrake cable too?
Thanks!
dstrout is offline   Reply With Quote
Old 12-24-2018, 04:46 PM   #19
No. The cable clips to the back plate.
Would this work to trick the tps sensor JToho Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-30-2013 05:49 AM
Trick to restrat on last map used on ecutek Mars2 Engine, Exhaust, Transmission 23 04-05-2013 05:30 PM
