Old 12-23-2018, 12:42 PM   #1
dstrout
dstrout's Avatar
Is there a trick to getting the rear hubs off?
Is there a trick to getting the rear hubs off? It removed the speed sensor and the 4 bolts that hold hubs to the carrier. I’ll be damned if I can get the hubs off. I’ve even tried one of those hub pullers that bolt to the wheel studs with a screw in the middle to push against the axle. I can get the axle about 1/2 way pushed in, but the bearings show no signs of coming out.
Car is a 2013 with about 58K miles on it. Any suggestions? I’m afraid I’m going to bend or break something.
Thanks,
Dave
dstrout is offline   Reply With Quote
Old 12-23-2018, 12:52 PM   #2
ls1ac
ls1ac's Avatar
Explain what you mean by hub.
Disk or axel.
Old 12-23-2018, 12:57 PM   #3
dstrout
dstrout's Avatar
This part. I’m trying to put on ARP extended studs
Old 12-23-2018, 05:11 PM   #4
ls1ac
ls1ac's Avatar
Ok, three thing that can be holding it.
the outer face of the inner hub
the splines
the bearing
Put the puller back on and snug it tight, using a large drift try to rotate the inner hub with a dead blow hammer. If the inner hub turns then it is either the bearing or the splines. At that point you can tighten up the puller as either the splines or the bearing will have to let go.
If it is the inner hub then spray it with wd pb or whatever let it sit over night and repeat. Then use heat on the back of the inner hub mount.
Old 12-23-2018, 06:47 PM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
Take off the drum brake and use an air hammer where the hub meets. If you want to be more gentle takr the whole hub and parking brake off the car. Put some lug nuts on the studs. Thread two of thebfour bolts half way in the back. Put socket on the bolts and pound it to knock it loose.
I didn't have an air hammer and pounding the bolts only worked on one of mine. In the pinch I ordered a hub/parking brake assembly from a low mileage wreck and installed it. I had a thread on it, I'll try and find it.
Old 12-23-2018, 06:50 PM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
Here was my experience
http://www.ft86club.com/forums/showthread.php?t=107114
Last post on page 4 was my solution
Old 12-23-2018, 06:56 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
That is a press-fit assembly of angular contact bearings. They are not coming apart without a serious press.
https://demos.starbase7.net/t3Portal...00V7H02FX.html
Old 12-23-2018, 07:19 PM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
[IMG]https://i.imgur.com/wkyI0o3.jpg[MG]
I think he wants to remove the whole hub bearing assembly? Or i misunderstood
Old 12-23-2018, 08:04 PM   #9
Ultramaroon
not playing cards
He's installing long studs. It's far enough apart if he has a vise or some flavor of that tool.
Old 12-23-2018, 08:38 PM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
I had to remove the whole assembly in the rear to install ARP extended studs. The studs I just used a sacrifical lug nut and a hammer to remove
Old 12-23-2018, 08:57 PM   #11
Ultramaroon
not playing cards
I extend my deepest sympathy to your wheel bearings.
Old 12-23-2018, 09:03 PM   #12
ZionsWrath
Thanks
ZionsWrath's Avatar
Old 12-23-2018, 10:08 PM   #13
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
you can use a ball joint separator from the hazard freight it costs like 20$ and works really well
Breadman is offline   Reply With Quote
Old 12-23-2018, 10:14 PM   #14
ZionsWrath
Thanks
ZionsWrath's Avatar
I have one. One blow with the hammer works well. I understand some will say this will damage your wheel bearing. I haven't seen that in my limited experience and i don't see how it is any worse than track driving. To each their own.
Would this work to trick the tps sensor JToho Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-30-2013 04:49 AM
Trick to restrat on last map used on ecutek Mars2 Engine, Exhaust, Transmission 23 04-05-2013 04:30 PM
