Old 12-12-2018, 08:27 AM   #1
Jcas
Jcas's Avatar
Drives: 2013 Limited Subaru BRZ
Need help with brake options
Hey guys, so I’m thinking about upgrading my brakes a little bit nothing to crazy but I just need some help. So I like the stock brakes they stop me pretty well but I’m just looking for something with a bit more bite! So I was wondering do you suggest maybe just get some different pads? If so which ones do you guys like personally for spritited backroad type driving not really track use. And if I get brake pads should I swap the stock rotors for some drilled or slotted rotors?
Any info is helpful and thanks in advance!
Jcas is offline   Reply With Quote
Old 12-12-2018, 08:47 AM   #2
JIM THEO
Drives: BRZ 2018
First in my list for spirited road driving suitable for track use are the following with this order:
Project mu 999, PF 011, Carbotech XP10-12, Ferodo DS3000, Carbon Loraine RC5+
I think very high initial bite gives Project mu but this isn't always good for low quality tarmac, CL RC5+ is more progressive...
JIM THEO is offline   Reply With Quote
Old 12-12-2018, 09:48 AM   #3
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
I got a set of Winmax W2 pads over the summer and used them for a few autocross days and spirited driving. I really like them.
BigTuna is offline   Reply With Quote
Old 12-12-2018, 10:05 AM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
If you want more bite, it will have to be the compound of the brake pad. You'll want something more towards performance which is not OEM. Stoptech 309 pads is a good step up, but you might get a little more noise. Stoptech 308 is going to feel pretty much like stock.
The slotted rotors will give you a better initial bite but it will eat brake pads a little bit faster. If you like to have the "race car look", drilled and slotted is the way to go and since you're not tracking, you don't have to worry too much about the drilled holes cracking.
Stock rotors should be fine with a more aggressive pad compound, but I would stay away from any track only pads since those only really work when they are up to temperature. Also, you might want to resurface your rotors (if you can depending on thickness), to try to minimize any vibration or squealing. Note, more aggressive pads may cause additional/quicker wear on rotors.
N1rve
Old 12-12-2018, 10:26 AM   #5
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Since you didn't mention anything about track days or autox I'm assuming this is all street driving. Upgrade to a slightly more aggressive compound, you won't need much for daily/spirited driving. Something like Winmax W1 or W2, Project Mu Type NS or HC+800, or Cabrotech 1521. I'd say the pads mentioned by @JIM THEO are way too aggressive if you aren't tracking.
As for rotors, simply replace with something like Centric blanks. No need for slotted/drilled.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 12-12-2018, 12:05 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Winmax W2 or W3 would be good for street/spirited driving.
Project Mu HC+ 800 would be my choice as the initial bite is amazing, but they dust like hell and only last about 30k miles for the fronts. They are cheap though so it kinda evens out. I rant them for 100k+ miles. Trying stoptech sports now but the bite isn't as good and will likely switch back when these wear out.
Carbotech tend to have a more linear feel imo, not the hard initial grab of Winmax or Project Mu.
OEM rotors are fine and way cheaper then slotted/drilled.
Old 12-12-2018, 12:22 PM   #7
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Winmax W2 with Non slotted or drilled & upgrade brake fluid is efficient.
Old 12-12-2018, 12:23 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I've been running the Ferodo DS2500. Just street and canyon driving. I haven't had any noise and work fine cold.
Old 12-12-2018, 12:54 PM   #9
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Like everyone else said, sporty street pads or mild hybrid pads, leave the OE rotors unless they're worn down (which is unlikely, these rotors are sturdy as fuck), drilled and slotted is a gimmick imo. Winmax W1/W2, Stoptech, TRD, PMu NS400, Hawk HPS 5.0, Carbotech 1521, Gloc GS1 etc. Follow bed-in procedure and call it a day.
Your car is 5 years old now (or more), also get a brake fluid flush. Anything up to DOT spec is probably fine, Castrol DOT4, ATE Typ 200. Motul RBF600 if you want to get fancy.
I have a set on order thanks for assuaging my fears about noise.
ineedyourdiddly
Old 12-12-2018, 01:09 PM   #10
FirstWinter
Drives: Car
Winmax W3 would be my pick because I've used them. Project Mu, G-loc, etc., all have suitable alternatives as well. You can contact a vendor/distributor to find something which suits your use. I would probably upgrade brake/clutch fluid. OEM rotors or blank Centric replacements are fine.
FirstWinter is offline   Reply With Quote
Old 12-12-2018, 01:37 PM   #11
teetsdownlow
Drives: 2015 FRS
I was stuck between Project Mu HC800, Winmax W3 and Carbotech AX6. Ended up with Carbotech AX6 and very happy with them. They are not ceramic compound so they will make noise in stop and go traffic but it's definitely not annoying to me or other drivers.
I am not a fan of Hawk or EBC pads so I ruled those out. I think AX6 would be what you are aiming for
teetsdownlow is offline   Reply With Quote
Old 12-12-2018, 05:52 PM   #12
Jcas
Jcas's Avatar
looks good!
Old 12-13-2018, 10:50 AM   #13
Teseo
Drives: frs
But the bling effect of those "race" rotors... i want them
Old 12-13-2018, 11:18 AM   #14
N1rve
N1rve's Avatar
I actually have the Wilwood Drilled and Slotted BBK, they do look pretty awesome -- Especially in Red and through my Work Wheels
N1rve
brakes, brz, pads
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 06:17 PM
2017 BRZ w/ Performance Package Brake options mjanmohammad Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 04-07-2017 08:12 PM
Brake Duct options? kosoku Tracking / Autocross / HPDE / Drifting 13 08-23-2013 08:45 PM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
Are there any decent brake kit options that are compatible with OEM wheels? DRACHENV6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 11-15-2012 04:07 AM
