Old 11-27-2018, 10:10 PM   #15
norcalpb
norcalpb's Avatar
Originally Posted by Brz_racer View Post
I also have an 18 tS, makes the exact noise your talking about. At first I was worried about it as well, but its just a noise this car makes. I'm sure other cars make this noise as well, it's just more pronounced on the BRZ because of the lack of sound deadening. It's nothing to be concerned about.
Exactly, it’s a spherical joint paired with hardly any insulation in the firewall/dash.
I put my stock V bars on and the noise went away, but quickly went back to the STi bars because a noise is liveable if you know it’s normal.
Old 12-10-2018, 02:01 PM   #16
Imprezzave
Drives: BRZ TS
Send a message via AIM to Imprezzave
Hi guys, I think I may have found a very inexpensive fix. I removed my V-braces and stuck some dynamat under each piece where they make contact with the firewall and fender. Reinstalled them and torqued the bolts to the point where the dynamat was squishing out on the sides of the bar and voila the noise is gone.
Imprezzave is offline   Reply With Quote
The Following 2 Users Say Thank You to Imprezzave For This Useful Post:
J1Avs (12-12-2018), norcalpb (12-12-2018)
Old 12-12-2018, 07:27 PM   #17
norcalpb
norcalpb's Avatar
Is this still working out for you?
Old 12-12-2018, 08:31 PM   #18
Imprezzave
Drives: BRZ TS
yeah, haven't had any issues since I put some dynamat in between the contact points
Old 01-12-2019, 08:23 PM   #19
norcalpb
norcalpb's Avatar
Just wanted to say I applied dynamat to the same areas and my noise is completely gone. Thanks!!!
The Following User Says Thank You to norcalpb For This Useful Post:
Imprezzave (01-13-2019)
Old 04-01-2019, 06:18 PM   #20
fatblackninja
fatblackninja's Avatar
Drives: 2018 BRZ tS
Whew, glad to know that this is common and nothing to worry about.
Strange for me, it only happens when the car is cold. After maybe 10-15 minutes, it disappears. Took it to the dealer and they didn't really do anything except retorque a few bolts. Came back driving home from the dealer lol.
Just glad to know it's nothing to be worried about!
fatblackninja is offline   Reply With Quote
Old 04-01-2019, 09:58 PM   #21
TheRichLife
TheRichLife's Avatar
Drives: 18' BRZ tS
Glad I came across this. I've noticed the same noise but it happened so infrequent I kept thinking I was hearing things.
Ill have to try to dynamat trick. Smart idea!
18' BRZ tS 300/500 (CBS)
TheRichLife is offline   Reply With Quote
rear end clunk in 1st rucfj159 Issues | Warranty | Recalls / TSB 8 03-10-2015 04:14 PM
Any one else getting a clunk when shifting? GreaseBall Engine, Exhaust, Transmission 2 11-26-2014 09:58 PM
Clunk when going into first gear? huma BRZ First-Gen (2012+) — General Topics 22 07-24-2014 06:49 PM
Whiteline Clunk fix trippinbillies40 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-26-2013 06:44 PM
E-Brake clunk? topazsparrow Issues | Warranty | Recalls / TSB 10 07-09-2013 12:23 AM
