Old 02-20-2015, 11:13 AM   #1
rucfj159
Drives: 15frs 89volvo765&780
rear end clunk in 1st
I have a 15 frs manual with about 1100 miles on it. sometimes when I put it in 1st when I am at a stop there is a loud clunking noise from the back of the car, seems like the rear end.
anyone else experience this issue?
anyone know what it could be?
rucfj159 is offline   Reply With Quote
Old 02-20-2015, 11:21 AM   #2
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
This has been addressed numerous times. My 2013 FR-S still does this and it's normal. It's the nature of this Aisin transmission. Your car is not broken.
2016 Camaro SS is offline   Reply With Quote
Old 02-20-2015, 12:13 PM   #3
Not abnormal on many RWD cars. Just the system taking up the bit of slack that exists with all the components between the engine and the wheels.
Freaks out people that are used to FWD (that doesn't have all these drive train parts) all the time.
Old 02-20-2015, 12:27 PM   #4
Koa
input shaft clunking from you engaging the tranny from a stop is normal and fine
Old 02-20-2015, 12:28 PM   #5
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
Had it on my 13 FRS and have it with my 14 BRZ. It's normal, to avoid the "clunk" clutch and shift to neutral, then clutch shift into first, shouldn't clunk after that if you're that worried about it
Wilso is offline   Reply With Quote
Old 02-20-2015, 12:38 PM   #6
bababooey
Drives: BRZ SWP Limited -6MT
ive noticed this as well, i usually get the clunk when traffic light turns green and im not ready for it. if it bothers you, i try to make a habit of clutch pedal in (down) for an extra second or so before moving shift lever into gear one.
Old 02-21-2015, 01:44 PM   #7
Poodles
Drives: 2015 Series.Blue
Bingo. Have to give the input shaft a little bit of time to stop spinning as it's going from idle speed of the engine to a dead stop as it's put into gear.
Old 02-22-2015, 09:23 PM   #8
rucfj159
Thanks y'all glad I don'thave anything to worry about
Old 03-10-2015, 03:14 PM   #9
Ethereal05
Ethereal05's Avatar
Drives: 2015 BRZ Series.Blue
Having only driven FWD my entire life I have picked up on this sound myself. Immediately figured it is the input shaft.
Ethereal05 is offline   Reply With Quote
Rear end clunk when shifting? HuntingtonFRS Issues | Warranty | Recalls / TSB 26 09-30-2024 11:10 PM
rear suspension clunk Gen Issues | Warranty | Recalls / TSB 67 04-03-2015 08:52 PM
Loud clunk from rear of car tennisfreak Issues | Warranty | Recalls / TSB 14 11-26-2014 12:55 PM
Installed V3's: Clunk From Right Rear eyedeez Northern California 5 04-07-2014 01:34 PM
Clunk sound from rear suspension. j-tan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 02-05-2013 12:39 PM
