Old 07-22-2012, 10:52 PM   #1
huma
Drives: ITR
Clunk when going into first gear?
Almost every time I shift into first gear, there's a loud clunk noise. Anyone else have this issue or know why it's doing this?
I have about 250 miles on my BRZ and the grinding/syncro crunch is now gone from second gear. I guess the triple cone syncro's had to be broken in?
I'm about 80 city/20 hwy and I'm getting 28 mpg on my first tank of gas. This is pretty amazing.
Can't wait to fully break in the vehicle and push my brz a little harder.
huma is offline   Reply With Quote
Old 07-22-2012, 10:53 PM   #2
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
This is normal according to most people.
This is the same tranny from the lexus IS line .. which is loud.
I personally like it.
you might wanna try search/technical sub forums
Old 07-22-2012, 11:04 PM   #3
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
It's normal. I think it's even mentioned in the owner's manual.
Grimlock is offline   Reply With Quote
Old 07-22-2012, 11:28 PM   #4
huma
Drives: ITR
Same transmission as the IS250? I'm a little disappointed, I thought they would've built a better or modified one for our cars
The auto transmission otoh is amazing. I would've purchased an auto if I didn't love driving manual so much.
Old 07-22-2012, 11:29 PM   #5
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I've only heard good things about them, I'll have to dig around to find that post and how much hp/torq they can handle.
I remember it being higher than anything I plan on in the next few years though.
Old 07-23-2012, 02:02 AM   #6
Chauntalei
Drives: Non-BRZ
It's based on the Aisin unit from the IS250, but it's been heavily modified. I don't have my source on hand, but I remember reading somewhere that approximately 80% of the parts have been changed out. Someone feel free to correct me if i'm wrong though.
Chauntalei is offline   Reply With Quote
Old 07-23-2012, 02:25 AM   #7
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
If you want to avoid that noise, you could press on the clutch in neutral for 3-5 secs before putting into 1st gear.
Sigh-on-Rice is offline   Reply With Quote
Old 07-23-2012, 01:46 PM   #8
Shinji2787
Shinji2787's Avatar
Drives: '85 AE86 Sprinter Trueno
This is more or less accurate. Its based on the same unit but not the same tranny.
Also I think I remember reading somewhere that this tranny unit cannot handle all that much extra torque and hp above stock safely... Someone feel free to correct me if I'm wrong though.
Shinji2787 is offline   Reply With Quote
Old 05-14-2014, 06:17 PM   #9
Kuros
Drives: 2014 FRS Raven. 2011 sti red (gone)
I know this is an old thread... forgive me.
But does anyone know the exact cause of the clunk?
Kuros is offline   Reply With Quote
Old 05-14-2014, 06:23 PM   #10
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Stock trans (not sure about clutch) is rated for just above 200 ftlb torque (about 210). In practice it's been found that it can handle above 300 just fine if you're nice to it. The number at which your trans gears go ka-boom is supposed to be 400. Don't get close to 400.
You'll obviously need a different clutch for those much bigger numbers, but the trans will hold them reasonably well enough. Otherwise, start looking into stronger gears that will hold higher tq without an issue.
^GT5 Replay Photo Mode^
Old 05-14-2014, 06:26 PM   #11
chas3wba0
chas3wba0's Avatar
Drives: Yes
Yes, the intermediate shaft is still spinning after you clutch in and come to a stop, so when you put it into 1st, it brings the shaft to an abrupt stop. Sometimes, you can feel the car get bumped forward a little bit. It's normal and can be avoided:
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 05-14-2014, 06:34 PM   #12
Kuros
Originally Posted by chas3wba0 View Post
Yes, the intermediate shaft is still spinning after you clutch in and come to a stop, so when you put it into 1st, it brings the shaft to an abrupt stop. Sometimes, you can feel the car get bumped forward a little bit. It's normal and can be avoided by clutching out in neutral first.
Thank you!
Appreciate that.
Old 05-14-2014, 06:38 PM   #13
wheelhaus
wheelhaus's Avatar
Chas3wba0 is correct. You're hearing the effect of the 1st gear synchro doing its job. The transmission is stopped, so selecting first forces the input and intermediate shaft to suddenly stop as well.
It is also repeatable after you've stopped. If you reengage the clutch in neutral before selecting first each time, the engine (via clutch) will spin the input shaft. If you hold the clutch in for 5-6 sec the input shaft and intermediate shaft will have enough time to slow down on their own, so when you select 1st it's silent because nothing is spinning.
wheelhaus is offline   Reply With Quote
Old 05-14-2014, 06:41 PM   #14
chas3wba0
chas3wba0's Avatar
Drives: Yes
Thank you!
Appreciate that.
No problem, I was confused when I first noticed it too and read a similar explanation somewhere else on this forum. Did a bit of research and confirmed that it is most likely true
Also corrected my post because my last statement was slightly inaccurate
Parking brake clunk FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 06-28-2012 12:10 AM
Parking/Emergency Brake - "Clunk" EsoBOFH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-24-2012 11:43 AM
Thud/Clunk when shifting. erom Engine, Exhaust, Transmission 10 06-17-2012 07:08 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
Top gear USA 4agze Off-Topic Lounge [WARNING: NO POLITICS] 25 12-08-2010 11:01 PM
