Old 11-30-2018, 12:45 AM   #1
kev0
Drives: '14
Best coilovers for daily driving?
Not tracking or anything. I just want some coilovers that will lower my car about 1.5 - 2 inches. What are the best coilovers under $700 that will help me achieve this?
What are the disadvantages of having cheaper coilovers versus the expensive ones like CSG Tein Flex A's?
kev0 is offline   Reply With Quote
Old 11-30-2018, 08:53 AM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
Tein Flex A is a cheap coilover... Though a good one, as they go. $700 new is a compromise. Tein Street basis or flex z maybe. Most stuff in that price range (new) is crap damping and crap ride.
Old 11-30-2018, 09:28 AM   #3
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Tein Flex A, HKS Hipermax, FA500 are all pretty nice.
MCTeeJ is offline   Reply With Quote
Old 11-30-2018, 09:33 AM   #4
AutoNewb
Drives: 2014 Subaru BRZ Sterling Silver
Under $700 coilovers are not worth it.
Disadvantages
-HORRIBLE ride quality due to cheaper springs.
-Cheap coilovers arent made with corrosion resistant materials... since you live in Chicago you get pretty snowy winters. Your coilovers will RUST due to the salt and snow. If you dont drive it in the winter SOME still will rust with rain.
-Not the best alignment adjustments.
My recommendation for daily driving? The KW V1. Perfect against all those reasons I said before. So save up or put it on a credit card. You will regret the cheaper Teins...
http://www.ft86speedfactory.com/kw-v...vers-1001.html
AutoNewb is offline   Reply With Quote
Old 11-30-2018, 09:33 AM   #5
alphasaur
friendly
Drives: 17' 86
I'm going to throw ST coilovers into the mix. They're effectively rebadged KW V1s without the INOX coating from everything that I have read.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 11-30-2018, 09:37 AM   #6
AutoNewb
You're definitely right. Its a better BANG for the buck if you don't drive in the winter or live in California. They will still rust in the salt and snow. Since the OP lives in Chicago, I wouldn't recommend them unless hes only driving in the summer.
Old 11-30-2018, 10:16 AM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
The best new coilovers under $700 are guaranteed to have garbage damping...
1. You will hate driving the car...
IMO you're better off buying a set of Swift BRZ Sport springs and keep the stock front upper strut mounts. These springs lowered my car 1.5" front and 1.25" rear. You might cut the bumpstops in half. This should give you close to the desired ride height without destroying the ride while saving you a few hundred $$$. Just do not run camber plates that reduce bump travel with these springs! You will hate the ride over the tiniest bumps if ya do...
Old 11-30-2018, 10:16 AM   #8
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
If your only goal is to drop the car, lowering springs on stock or aftermarket shocks will be a much better quality option within that price range. If you're daily driving you don't need the adjustability of coilovers.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 11-30-2018, 11:26 AM   #9
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Tein Street Basis Z Coilover
http://www.ft86speedfactory.com/tein...l#.XAFkX9tKiUk
But I would spend the extra 100 or so and get the Flex Z
http://www.ft86speedfactory.com/tein-super-low-flex-z-coilovers-2013-ft86.html#.XAFkmttKiUk'
N1rve
Old 11-30-2018, 11:56 AM   #10
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
There simply isn't many coilovers under $700. Raceland ultimos, Godspeed, Tein basis... just to name a few.
If you are simply going for the low look and don't care about ride quality ^
tyler_win_photo is offline   Reply With Quote
Old 11-30-2018, 12:02 PM   #11
lantsalot
Derp
lantsalot's Avatar
This. If you're not wanting to drop the big money on coilovers and you don't need to adjust, you're probably better off getting springs. I've had a good experience with the TRD springs on stock shocks for about the last 3 years here--can imagine that getting aftermarket shocks would make it a pretty nice ride.
lantsalot is offline   Reply With Quote
Old 11-30-2018, 12:20 PM   #12
JIM THEO
Drives: BRZ 2018
Why you search for coilovers for DD, try the Showa tuning evolution that have dual flow valves as Ohlins and are quite comfortable and sport the same time for spirited road driving!
Otherwise something like Cusco touring A adjustable shocks and a set of pink STI or other lowering springs will suit you better.
JIM THEO is offline   Reply With Quote
Old 11-30-2018, 12:35 PM   #13
These ^. Another spring option is the RSR Superdowns. Nice drop and work well with the stock shocks. I have 120K on them through all seasons and have had zero issue.
Old 11-30-2018, 12:38 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
After installing coils on my car; I dont think they are "GOOD" for DD. You can DD them, yes no problem. But, Springs are GREAT for DD!
So, there is my $0.02
(I'm running 6th gen FA500s)
I LIKE TIRES!
What Are Your Pet Peeves of Daily Driving (Your FRS/86)? Little Mt. Fuji Scion FR-S / Toyota 86 GT86 General Forum 100 11-16-2018 05:16 PM
Daily Driving/Spirited Driving Brakes VABeachBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-12-2017 04:11 PM
Best Tires for Daily Driving Fun tez2013 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 01-31-2016 06:11 PM
Best coilovers for daily driving/durability Hentai Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 11-24-2015 01:32 PM
MSSP PSI for daily driving? jflogerzi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-17-2014 08:49 PM
