Old 03-02-2017, 12:30 PM   #57
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Well I might try a different firestone location then. It shouldn't be that hard if all they have to do it fix the toe right?
Or does messing with the toe also affect camber? And therefore makes the process a little more longer?
Alltezza is offline   Reply With Quote
Old 03-02-2017, 12:45 PM   #58
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yes, but it's not unduly hard with a modern rack.
However, I believe the machine will tell them that adjusting the rear requires adjusting the front. It won't be true in this case since you're relatively close to where it needs to be, but they'll bitch about it anyway.
ineedyourdiddly
Old 02-22-2018, 04:44 PM   #59
Alltezza
Alltezza's Avatar
Well a year later and here I am sitting at firestone getting a realignment hopefully they got it right this time.
I have the front and rear toe at 0 for simplicity hopefully they'll get both sides to match.
I'll update this post in an hour or so
Update: 5:21PM they told me they broke the bolt on top of my camber plate to adjust the camber, but they had another one in their inventory to use. (I don't know how that happens.....I have no idea how an alignment works but I'm guessing it snapped from over torquing)
Update: Finished at 6:15PM
I just hauled ass home, and it damn sure drives a lot better and based on the numbers sheet it looks like he got exactly or pretty close to what I wanted compared to last time. This time everything is pretty equal on both sides.
-2 Front
0 Toe Front and Rear
-1.5 Rear
Old 03-24-2018, 09:41 AM   #60
DeltaEcho
DeltaEcho's Avatar
Drives: 17BRZ Limited TS
This is what I have been running for at least 6 months after Coilovers (1.5 inch drop) and no other suspension mods
Based off suggestions, I am going to add more Camber to the front - 1.2 and keep the rear at - 2.1.
Then get the total toe in the front back to 0 and rear total 1/16
Note: my front and rear toe I was deeply disturbed to find out it was really off just now. But it will be fixed once I get my new wheels
Sent from my G8142 using Tapatalk
DeltaEcho is offline   Reply With Quote
Old 11-22-2018, 12:45 AM   #61
gpvecchi
gpvecchi's Avatar
Guys, when you're talking of 1/16 of rear toe in, are you talking in inches or degrees?
Old 11-22-2018, 10:51 AM   #62
strat61caster
Inches based on a 25" wheel diameter so you can calculate 1/16" to be ~0.14 degrees
ineedyourdiddly
Old 11-22-2018, 12:36 PM   #63
gpvecchi
gpvecchi's Avatar
This is even more complicated. In Italy many measure toe with mm. I set mine to 1.60mm total. Is this correct?
Old 11-22-2018, 03:12 PM   #64
JIM THEO
Drives: BRZ 2018
Same here, 1mm is about 7' for 17" wheels and is a good amount of toe out front for better response!
JIM THEO is offline   Reply With Quote
--00 (rev) or redline setting -Willis-86touge Issues | Warranty | Recalls / TSB 29 06-01-2016 04:05 PM
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
Setting up for a night Chen Northwest 15 09-20-2013 03:10 AM
This is how I pan on setting my car up where does it put me jdzumwalt Tracking / Autocross / HPDE / Drifting 16 02-10-2013 10:24 PM
