go_a_way1
Old 10-15-2018, 05:43 PM   #3921
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by B 86 View Post
Thanks for the help! I haven't bought the tires yet but the reason I was going to go with that tire size was for the look from the setup I saw on a build. If I went with one of those other setups would it change how much it would fill up the wheel gap and comfort of the ride? Also what does the added 1 pound mostly effect?
If you want a certain look, then got for it. They will work. A larger diameter tire will fill up the wheel well more than a smaller diameter tire.
IMO, the ride will be very close to the same on all the tires; shocks/springs have more to do with ride quality.
Added weight will slow you down and increase braking distance. Though I don't know exactly how much; probably only a little..
They say one pound of wheel/tire weight removed is as good as removing 10lbs off the car body.
Good luck!
I LIKE TIRES!
B 86 (10-15-2018)
Old 10-16-2018, 03:22 PM   #3922
Sev995
Drives: Black 2013 frs
18x9.5 on stock suspension
Hi, so I have stock suspension on my 2013 frs, and I'm looking to get some 18x9.5s on the car. Currently, I'm looking at the avid-1 av20s (+38, 5x100, 73.1) with some tires that are 255/40R18 W or 255/35R18 W. Will any of these fit?
Sev995 is offline   Reply With Quote
Old 10-16-2018, 04:21 PM   #3923
Leonardo
Country Boy 4 Life
Leonardo's Avatar
First of all.....
Welcome to the forum!
I think you will rub in the front with a 255 tire.
The front's clearance between the wheel and spring perch is the issue. A 17x9 +45 is what I consider the inner tolerance, and the 18x9.5 +38 is only 0.7mm farther away from the spring perch. A 255/40 is too big in diameter.
I would get narrower tires like 235/40 or 245/35/18 tires and some 3mm slip spacers. You will not be able to add camber, there is no room without a spacer. (or coilovers) The thicker the spacer you add up front, the more inner clearance you will have to add camber, but this adds poke at the same time. Read post
Read post 213, 214, & 219.
http://www.ft86club.com/forums/showt...=28017&page=16
Stock diameter 24.6"
255/40/18 diameter 26.0"
Good luck! __________________
I LIKE TIRES!
Old 11-02-2018, 10:06 PM   #3924
Rai-zero
Drives: Legacy
quick question.
this is about offset. I saw these are approved on Tirerack for the BRZ with PP
18x8 will be running 225/40
Have the offset of
42
45
48
I did the calculators and seems like 42 are even (inside) to the stock and most pushed out.
the others seems like less flush and more pushed inside.
would you recommend the 42 as the better fit? I don't want them to stick out but closer to flush would be better.
Note I have a tS but Tirerack has not tested anything on a tS but does say these will fit on the BRZ PP
Tirerack does have some with smaller positive offset such as 40 or 38 but those are heavier and I was looking at the three mentioned first with the weight in mind.
thanks
Rai-zero is offline   Reply With Quote
Old 11-07-2018, 10:58 AM   #3925
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Rai-zero View Post
quick question.
Have the offset of
42
45
48
thanks
It depends on what you want. I had 225/40 on 18x8 +45 with a +25 spacer. This makes them 18x8 +20. I was lowered 1" with a set of camber bolts in the front. IMO, They were flush and looked awesome.
I'm currently running 18x9 +30 front. Compared to a 18x8 +42, my setup pokes 25mm more.
Those offsets are not flush. You could always add a 25mm spacer and get any of the three offsets. (depending on how aggressive you want to look, and the other suspension mods you are planning)
If you do not want spacers, get the +42.
I LIKE TIRES!
Old 11-21-2018, 05:01 AM   #3926
Mehrshad
GT86PersianClub
Mehrshad's Avatar
Drives: 2014 Crystal Black Silica GT86
Hi guys
My friend got Enkei Kojin wheels 18x9.5 +45 square,and he has Tein Street basis Z coilovers,he’s gonna get 235/40 tires
I wanted to know if he’s gonna have rubbing issues or not?
Follow Me on Instagram: @Stock_GT86
Admin & Founder of @GT86PersianClub
Nur Spec Body-Rays Gramlights 57Xtreme-Rays Dura Nut L42 Straight type Lug nuts-EBC Brake Rotors-K&N Filters-D2 Racing RS Coilvers-GReddy EVOlution GT Catback-HKS Dual Resonated Front Pipe-JDL Catted UEL Header-Valenti FT86SF tail light & 4th Brake light
Mehrshad is offline   Reply With Quote
Old 11-21-2018, 10:23 AM   #3927
Vital
Drives: 2015 BRZ
Originally Posted by Mehrshad View Post
Hi guys
It should not rub if he is gonna be getting coilovers. Also, see if he can get 245/35 size tires as they are pretty similar to stock specs.
The Following User Says Thank You to Vital For This Useful Post:
Mehrshad (11-21-2018)
Old 11-21-2018, 10:46 AM   #3928
Mehrshad
GT86PersianClub
Mehrshad's Avatar
Actually the 245/35’s are very rare here and we didint find them,and yes he has coilovers
I have 18x9.5 +40 with 255/35’s with D2 coilovers,and i had very very small rubbing issue on full lock at first when i got the wheels,but after a couple of months its fixed and no rubbing!!
The Following User Says Thank You to Mehrshad For This Useful Post:
Vital (11-23-2018)
Old 11-21-2018, 11:36 AM   #3929
JIM THEO
Drives: BRZ 2018
wheel poll
Question, I am going to change my quite new wheels for a set of 18X8" TSW but I can't choose which one, I am between two designs, the forged Nurburgring and the Mallory 5.
I don't want my car only for the looks, if something doesn't serve it's purpose I'd change it for something better performance wise, thus, a lighter wheel is always welcome.
The Mallories are 43lbs with the Pilot supersports 215/40/18 I have while Nurburgrings are 39lbs and slightly lighter combo even from the oem 17" wheels/tires.
My mind says Nurburgrings 18X8 +45 but my heart leans to Mallories 18X8 +35...and finally if I choose the Nurburgrings what offset 35 or 45?
JIM THEO is offline   Reply With Quote
The Following User Says Thank You to JIM THEO For This Useful Post:
Leonardo (11-21-2018)
Old 11-21-2018, 12:09 PM   #3930
Leonardo
Country Boy 4 Life
Leonardo's Avatar
+35 is better, IMO. More flush.
As for the weight difference compared to looks. The difference is small enough, you won't notice it for DD. So if the Mallory makes you happier to look at, then it may be the choice.
But, if weight is the main factor; why not get 17x8 Nurburgrings? Either way, 17 or 18 Nurburgrings are nice wheels.
I went with a wheel: I wanted to look at, in my price range, that was also as light as possible. My 18x9 with 245/35 weighs 43lbs.
Great choice on tire size! They will look awesome on 18x8s!
I LIKE TIRES!
JIM THEO (11-21-2018)
Old 11-21-2018, 03:11 PM   #3931
JIM THEO
Drives: BRZ 2018
Just for comparison:
Old 11-21-2018, 10:16 PM   #3932
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The Nurburgring looks just like that. The 18x8 Mallory will look less concave. It's weird that TSW does not list two different face types. But after looking at the specs available, and pics on google, I'm 100% sure the concaveness will look like this...
via Imgflip Meme Generator
I LIKE TIRES!
JIM THEO (11-22-2018)
Old 11-22-2018, 03:28 AM   #3933
JIM THEO
Drives: BRZ 2018
I already found some photos from both and yes Mallories are less concave, the problem is if I fit the 43lbs Mallory combo with +35 offset the mass will be by far away from center of wheel/hub so actually it should make a difference to overall performance and comfort while Nurburgrings are forged +45 which means the mass of the wheel is more centered!
Old 11-22-2018, 10:39 AM   #3934
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Have you tried it and felt the difference? I seriously do not think 10mm offset will be felt at all in this case. IMO, you are overthinking things. Weight is important, but so are looks. If you look at the Nurburgrings and wish you got Mallorys every time; I feel the bit of weight difference will not matter at all.
If all you do is worry about the "lost" performance from 10mm of offset and a few extra pounds; then get lighter weight wheels. (like 17" Nurburgrings)
IMO, Both wheels will feel the same, especially with the same tire.
It's your car, do what makes you happy.
I LIKE TIRES!
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
