Old 11-06-2018, 04:36 AM   #1
CrozOver
Drives: 2013
Question Something missing under the Hood?
Just bought a used GT86, i noticed that some part is missing, next to the air filter box? What is it and should i go to Toyota and buy the missing part ASAP?
Regards
https://imgur.com/a/FTkQyn7
CrozOver is offline   Reply With Quote
Old 11-06-2018, 04:54 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
You are missing part of the intake, was yhe car wrecked? Mine broke from a minor front end hit. That or the previous owner likely had an aftermarket intake.
Air Inlet Duct - Subaru (46012CA000)
Air Cleaner Body - Subaru (46059CA000)
I'd take the bumper off and looks
The Following User Says Thank You to ZionsWrath For This Useful Post:
norcalpb (11-07-2018)
Old 11-06-2018, 05:05 AM   #3
CrozOver
Drives: 2013
I know that the car was in a minor parking accident and the front bumper was repainted. Going to the dealer to order a new one.. thanks for the reply!
Edit: is it dumb to drive like that?
Old 11-06-2018, 05:26 AM   #4
86MLR
86MLR's Avatar
Also plug the flange for the sound tube, you can get a rubber cap from a auto shop for a couple of bucks.
Old 11-06-2018, 05:37 AM   #5
CrozOver
Drives: 2013
I've heard about that! What's the pros about that?
Old 11-06-2018, 07:29 AM   #6
86MLR
86MLR's Avatar
The pic is missing a sound generator tube, its useless and a gimmick.
The issue with it being removed is that it leaves a hole in the airbox, that hole will suck in hot air from under the bonnet, thus to a point adding to higher intake temps, this is bad.
As you are missing the snorkel to it seems, this will also suck hot air to a point.
Google:
1.Toyota 86 sound tube delete
2. Toyota 86 Snorkel mod
Both these searches will give you a better idea of the parts.
The rubber plug is a easy fix, a plug and a cable tie will fix that.
The missing snorkel may be found at a breakers yard, cost is ????, or you can easily fabricate something, it really only needs to be a couple of inches long, that will put the intake just inside the front bumper, and get the intake cleaner, read: not under bonnet, air.
And...... .Google
Old 11-06-2018, 08:04 AM   #7
new2subaru
Weight Weenie
Drives: 15 FR-S
Is the foam gasket between the air box and bumper there?
Old 11-06-2018, 08:20 AM   #8
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Google:
And...... .Google
Sorry but I have to intervene before anymore misinformation comes into this guy's thread.
He is NOT missing the sound generator tube. He is missing one of the resonators in the intake system.
I've attached a picture and the item circled in red is the sound generator tube and the item in green is the resonator he's missing.
Joon525 is offline   Reply With Quote
The Following User Says Thank You to Joon525 For This Useful Post:
ls1ac (11-06-2018)
Old 11-06-2018, 08:23 AM   #9
CrozOver
Drives: 2013
Thanks for all of the replys! I went to the local junkyard and found the Air Cleaner Duckt for 45 bucks! Going to install it tomorrow and Also make my own ”tube” so the engine wont suck in hot air.
Got this https://www.ebay.com/itm/OEM-2013-20...-/202284404124
Yes it seems like the foam gasket is still there
Old 11-06-2018, 08:25 AM   #10
CrozOver
Drives: 2013
You are right!
Old 11-06-2018, 08:40 AM   #11
86MLR
86MLR's Avatar
Yeap, my mistake, I really should wear my glasses more.
Same cheap fix though.
Old 11-06-2018, 11:27 AM   #12
gravitylover
Does that resonator serve any purpose? If it was gone would it matter?
Old 11-06-2018, 11:29 AM   #13
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
I believe Mishimoto saw better results with it on when testing their inlet tube.
Weigaldo is offline   Reply With Quote
The Following User Says Thank You to Weigaldo For This Useful Post:
gravitylover (11-06-2018)
Old 11-06-2018, 12:03 PM   #14
Grady
Grady's Avatar
Yes it resonates.
You also appear to be missing a turbo also!
The Following 2 Users Say Thank You to Grady For This Useful Post:
bcj (11-06-2018), gravitylover (11-06-2018)
Missing??? Papi BRZ First-Gen (2012+) — General Topics 17 06-23-2015 03:08 PM
Florida: Trade Silver hood for Black hood 555 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2015 11:52 AM
So... am I missing something? BirdTRD Issues | Warranty | Recalls / TSB 10 11-04-2013 05:52 PM
missing my FRS :( 20valvewynn83 Southern California 36 08-29-2012 04:12 AM
